Is It Possible To To Create A Stepped Cross Section?
4hotshoez
You can fudge it in layout. Cut two different sections, one for each step. Send both to layout. Drag the edges of the layout boxes so the stepped cuts are displayed properly, side-by-side. In plan, you'll have to manually draw a stepped polyline with callouts on the ends.
To expand on Roberts answer you can create 2 side clipped sections. Use a line to accurately place the extent of the side clip. Snap these two sections together in your layout. In the attached images the section markers are live section cameras. (The horizontal line is a cad line but you can set it's properties to match your section line.)
