Ange822 Posted November 10, 2020 Share Posted November 10, 2020 I am drawing a cross section using 2D CAD lines (to get more detail than the automatic cross section Chief creates). I am having issues finding a Batt Insulation Pattern to use. I am using Chief X9 - Chief Architect has a Block under "CAD Blocks / Detail Components / Insulation / Batt / 5.5" R-21", but unfortunately it is only 12" x 5 1/2" of size, so if I want a smaller or bigger section, it stretches the block and the proportions change. - I found a free .PAT file online (attached), but It needs to be in a specific location to work, the minute I move the polyline with that pattern in it, the pattern moves with it. I have tried to illustrate this in the attached screen shot. Please let me now if anyone has any recommendations / solutions to this issue. thanks, Angela H1INSUN1.pat Link to comment Share on other sites More sharing options...
Chopsaw Posted November 10, 2020 Share Posted November 10, 2020 They introduced pattern offset controls in X11 but even with that option you may be better off just cad blocking your polyline before you move it and it can still be adjusted for height as a cad block. Link to comment Share on other sites More sharing options...
Ange822 Posted November 10, 2020 Author Share Posted November 10, 2020 13 minutes ago, Chopsaw said: They introduced pattern offset controls in X11 but even with that option you may be better off just cad blocking your polyline before you move it and it can still be adjusted for height as a cad block. Okay - could you explain how I do that? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted November 10, 2020 Share Posted November 10, 2020 See if CAD>Boxes>Insulation does what you're looking for. By the way, if you Explode that insulation CAD Block, you'll see that all they did was use an Insulation Box. 1 Link to comment Share on other sites More sharing options...
LevisL Posted November 10, 2020 Share Posted November 10, 2020 1 minute ago, Alaskan_Son said: See if CAD>Boxes>Insulation does what you're looking for. That's what I was thinking too. Way easier than stretching CAD blocks or messing with patterns and offsets. Link to comment Share on other sites More sharing options...
Chopsaw Posted November 10, 2020 Share Posted November 10, 2020 13 minutes ago, Ange822 said: Okay - could you explain how I do that? Michael's suggestion may be just what you need but if not Shift select or Marque select the polyline and on your active toolbar click the Make CAD Block tool. Link to comment Share on other sites More sharing options...
Ange822 Posted November 10, 2020 Author Share Posted November 10, 2020 8 minutes ago, Alaskan_Son said: See if CAD>Boxes>Insulation does what you're looking for. By the way, if you Explode that insulation CAD Block, you'll see that all they did was use an Insulation Box. I have tried that, it doesn't explode unfortunately. Link to comment Share on other sites More sharing options...
Ange822 Posted November 10, 2020 Author Share Posted November 10, 2020 9 minutes ago, Alaskan_Son said: See if CAD>Boxes>Insulation does what you're looking for. By the way, if you Explode that insulation CAD Block, you'll see that all they did was use an Insulation Box. Oh wow okay nevermind that does work!! I thought you wrote "block" not BOX. Awesome thanks everyone for your help. Angela Link to comment Share on other sites More sharing options...
