M-Ferioli
How to make half a room open to the 2nd floor ceiling
Hi all,
   I'm an interiors only guy and don't really do much with the structure of the building so this is new to me.  I'm trying to figure out if there is any easy way to make a basic rectangle 2 story structure with half the interior open all the way to the roof.  I can't seem to find video that does what I need.  Seems like it might be easy, I just don't know where to start.  I tried using a hole but that left gaps in the walls.  Could some one point me in the right direction to learn this?
Thanks!
Mike
Mike:
It would help if you post your plan but from what you describe it sounds like you need to define the space where you want on open ceiling using the room divider tool. Once you've done that, select the room, open the DBX and, in the ceiling section of the Structure tab, uncheck 'Flat Ceiling Over This Room' .
Eric
Eric,
  Thanks for the reply.  I did that, but I also had to divide the room on the second floor and uncheck the "floor under this room" option.  now half of the room is open all the way up.  I think this accomplish what I need.
Thanks again for the quick and helpful reply!!
Mike
You can also select the room above and in the 'General' tab, define the 'Room Type' as "'Open Below'.
Hi Mike,
Is this what your needing to do?  If so, its simple.. just go the second floor, and after drawing your dividing line, the room you want to be open below, go to the room dbx and rename to "open below"
awesome!  That seems like it might be more of a proper way to do it.
Thanks a lot to both of you, really helpful.
Whenever I do an Open Below room I say to myself, Look Out Below! :D  Having worked as a framer, I can say things are a little spooky until you get those temporary guard rails built.
    28864
    giabaogroup2012
    giabaogroup2012
