Christina_Girerd Posted September 9, 2020 Share Posted September 9, 2020 Any suggestions for the best way to make this shaped parapet wall? I figure I can do it with polyline solids if necessary, but wondering if there is something better. Thanks. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 9, 2020 Share Posted September 9, 2020 There are several threads on parapet walls but it looks like you should be able to do that with a wall and wall material regions as it appears to be all straight lines and not arcs. I would draw a cad line and copy it a few times to snap the wall top to and don't make the mistake of clicking "Default Top Height". 1 Link to comment Share on other sites More sharing options...
robdyck Posted September 9, 2020 Share Posted September 9, 2020 Keep in mind that polyline solids can give you display control in plan view as well, making it simple to identify the various elevations in plan view. And their material will blend with the wall material below as long as the surfaces are flush. Perfect for elevations and 3d views. Add a floor for the parapet walls and/or low slope roof. Link to comment Share on other sites More sharing options...
Christina_Girerd Posted September 9, 2020 Author Share Posted September 9, 2020 Thank you both. I'm doing a quick review of Chief's flat roof & parapet how-to videos also. Link to comment Share on other sites More sharing options...
Christina_Girerd Posted September 10, 2020 Author Share Posted September 10, 2020 I pulled in an elevation image, sized it, then put it behind the building elevation and used the "break" tool to shape the top of the wall. Worked well. The wall niche tool worked well for the insets. 3 Link to comment Share on other sites More sharing options...
Chopsaw Posted September 10, 2020 Share Posted September 10, 2020 Nice Job. And quick too. That is a lot of sq ft. for one day. I bet you had fun measuring that one. Link to comment Share on other sites More sharing options...
Christina_Girerd Posted September 10, 2020 Author Share Posted September 10, 2020 Thankfully I didn't have to do any measuring. The client had already used a firm that specializes in as-builts by the time they connected with me, but that firm only did plans and elevations. I'm doing the 3D so they can produce some images for a donor campaign as they are a non-profit homeless shelter and related services. Been in that building since about 1950. They've done a few remodels over that time, but ready for another. Before that it was a chemical company. I haven't really started doing the inside yet - meeting with the client tomorrow to figure that part out. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 10, 2020 Share Posted September 10, 2020 Sounds like a fun project. Wall material regions would have cut the first layer of double brick? Or not. Ok I see it is better to just set the exact depth of cut. Then you don't need to mess with the wall definition. Link to comment Share on other sites More sharing options...
Christina_Girerd Posted September 10, 2020 Author Share Posted September 10, 2020 This is interesting - I just noticed that the top edge shows the stucco on the angled parts of the wall, but the wood for the straight parts. I'm planning to just change the wood texture to be stucco but was surprised to see this. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 10, 2020 Share Posted September 10, 2020 11 minutes ago, Christina_Girerd said: This is interesting - I just noticed that the top edge shows the stucco on the angled parts of the wall, but the wood for the straight parts. I'm planning to just change the wood texture to be stucco but was surprised to see this. Interesting. I would try a wall cap. Then you don't need to mess with the wall framing. Link to comment Share on other sites More sharing options...
Christina_Girerd Posted September 10, 2020 Author Share Posted September 10, 2020 Yes - that is faster than messing with materials in the wall type dbx since Chief annoyingly won't let me change materials with the eyedropper for wall "insides." Here's what a got with the standard "Cap 01" wall cap at the default 3/4" thickness. I left the cap in the other material just to show how it applied. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 10, 2020 Share Posted September 10, 2020 9 minutes ago, Christina_Girerd said: Here's what a got with the standard "Cap 01" wall cap at the default 3/4" thickness. How about 1/2" or 1/4" and the same finish as the walls. Was there a flat spot on top of the angled section in the middle of the window bank before ? Link to comment Share on other sites More sharing options...
Christina_Girerd Posted September 10, 2020 Author Share Posted September 10, 2020 The angled section goes to a point and is not flat - that is just the odd way the wall cap applied itself. First pic shows the wall profile. Second shows the 1/4" cap, different material. Third shows 1/4" cap in same material. Last shows no cap, and wall framing changed. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 11, 2020 Share Posted September 11, 2020 Well that is kind of sad that it did not work since that is what the feature is for. Might be worth sending tech support a link to your last post. Seems like it could use some improvement. Glad you original idea worked out. I suppose you could just paint the top plate without wrecking all your wall framing. Link to comment Share on other sites More sharing options...
mtldesigns Posted September 11, 2020 Share Posted September 11, 2020 Great job Christina, very cool~ Link to comment Share on other sites More sharing options...
Christina_Girerd Posted September 11, 2020 Author Share Posted September 11, 2020 Thanks. And yes, I'll put something in a bug report about the capping problem. Link to comment Share on other sites More sharing options...
