builtright3 Posted August 23, 2020 Share Posted August 23, 2020 Here is the plan file I altered if you want it test.planFetching info... Link to comment Share on other sites More sharing options...
rockyshepheard Posted August 23, 2020 Author Share Posted August 23, 2020 I followed solver's method and got it to work on a newly created set of four walls. Trouble is it doesn't work in a scenario where I already have the structure built and am just trying to add textures after the fact. I really don't want to start all over from scratch just to get a pony wall on this corner. Link to comment Share on other sites More sharing options...
rgardner Posted August 23, 2020 Share Posted August 23, 2020 On 8/23/2020 at 3:57 AM, rockyshepheard said: I followed solver's method and got it to work on a newly created set of four walls. Trouble is it doesn't work in a scenario where I already have the structure built and am just trying to add textures after the fact. I really don't want to start all over from scratch just to get a pony wall on this corner. Expand Just change the walls in your existing plan. Just make sure the first floor wall, and the pony wall lower wall are the exact same wall and on align at outer main layer. Link to comment Share on other sites More sharing options...
rockyshepheard Posted August 23, 2020 Author Share Posted August 23, 2020 thanks all Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 23, 2020 Share Posted August 23, 2020 Rocky, your problem seems to be that you’re reading things very nonchalantly without any regard for the proper definitions of the terminology being used. Nobody at any time told you to use an Eyedropper or a Material Painter. In fact, I believe someone specifically told you NOT to. What we all told you several times was to CHANGE your Wall Type. This is a very important Chief Architect term. Changing the Material is not changing the Wall Type. You need to change the Wall Type. Link to comment Share on other sites More sharing options...
