GeorgeDosil Posted August 19, 2020 Share Posted August 19, 2020 I'm in the middle of doing a plan and this strange icon or symbol shows up out of nowhere and follows my cursor. I attached a screenshot. Link to comment Share on other sites More sharing options...
rlackore Posted August 19, 2020 Share Posted August 19, 2020 That cursor indicates that you have angle snaps turned off. Turn angle snaps on, and the icon will disappear. Link to comment Share on other sites More sharing options...
rlackore Posted August 19, 2020 Share Posted August 19, 2020 You can turn this behavior on/off in Preferences: Link to comment Share on other sites More sharing options...
Dermot Posted August 19, 2020 Share Posted August 19, 2020 It is not recommended to turn off all of the behavior indicators in your preferences. This will only hide problems. If you accidentally turn off something like angle snaps and then draw out a plan, you will have lots of problems because nothing will be on even angles. There are lots of other indicators that you may miss as well. Link to comment Share on other sites More sharing options...
steve_stuart Posted August 19, 2020 Share Posted August 19, 2020 If you are unaware you can turn them on and off by clicking this icon. Link to comment Share on other sites More sharing options...
Dermot Posted August 19, 2020 Share Posted August 19, 2020 Angle Snaps can be toggled on or off through the menu, your preferences, or as Stephen has pointed out, through a toolbar button. You could also setup a hotkey for this but I don't believe we have one setup by default. The most likely case is that you accidentally hit the toolbar button. Link to comment Share on other sites More sharing options...
GeorgeDosil Posted August 20, 2020 Author Share Posted August 20, 2020 Thanks all...I'm grateful for the help...like Dermot said, I probably hit the button by mistake and shut it off. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 21, 2020 Share Posted August 21, 2020 19 hours ago, GeorgeDosil said: Thanks all...I'm grateful for the help...like Dermot said, I probably hit the button by mistake and shut it off. These are the Others you might run into some day.... Link to comment Share on other sites More sharing options...
