OnlineBuilder2 Posted August 14, 2020 Share Posted August 14, 2020 Is there a quick way to do this roofline? I tried putting another level above but its not working. I've done this years ago but can't get it now Link to comment Share on other sites More sharing options...
glennw Posted August 14, 2020 Share Posted August 14, 2020 In the 2 end walls dbx, go to the Roof panel and use the Dutch Gable Wall option. Auto build roofs. Or..it looks like there may be a double pitch. In which case, in addition to the above, open the walls dbx for the 2 long walls and enter the Upper Pitch options. Auto build roofs. Here is a very quick one: Link to comment Share on other sites More sharing options...
joey_martin Posted August 14, 2020 Share Posted August 14, 2020 Set it up in the roof and wall dbx before hand. Link to comment Share on other sites More sharing options...
SNestor Posted August 15, 2020 Share Posted August 15, 2020 @OnlineBuilder2 - did this video for someone on Chief Talk a while back...may help. Link to comment Share on other sites More sharing options...
glennw Posted August 16, 2020 Share Posted August 16, 2020 Steve, Great video as usual, but probably MUCH easier to do a simple roof like that using the auto roof tool. Build a zero height second floor and control the dormer with a room on the second floor. The big advantage of doing auto is that the model is very easy to change if you want to see how variations will look - or, if in a very unusual circumstance, the client changes their mind and wants some changes! I realise that it was an older video not necessarily made for this particular situation. 1 Link to comment Share on other sites More sharing options...
SNestor Posted August 16, 2020 Share Posted August 16, 2020 1 hour ago, glennw said: Steve, Great video as usual, but probably MUCH easier to do a simple roof like that using the auto roof tool. Build a zero height second floor and control the dormer with a room on the second floor. The big advantage of doing auto is that the model is very easy to change if you want to see how variations will look - or, if in a very unusual circumstance, the client changes their mind and wants some changes! I realise that it was an older video not necessarily made for this particular situation. Yea- auto build is the way to go. Link to comment Share on other sites More sharing options...
