lavorhaynie
Any idea where this plywood decking is coming from?
Where is this ply deck coming from?  See pics.  The highlighted ply is highlighted using the "Delete Surface" tool.
Plan file backup is also attached.
The plywood decking spans over three rooms, porch, breakfast and a portion of the garage.
Thank you for sleuthing this. Any help is much appreciated!
LM27BU.zip
I’m away from my computer but I’m guessing that area is defined as a room but it shouldn’t be or should at least be changed to an Attic room.
They are your Porch (+Breakfast) ceilings.
Your ceiling heights are too high and are building above the roof.
Lower the Porch ceiling heights, or...raise your roofs.
Michael, that is what I thought but there is no room defined in any of the highlighted area on the second floor or attic.
Its coming from the garage...still working on it.
Bonus Room. Turn on the attic walls. Give them room definition. Specify the attic space as "ATTIC"
image.thumb.png.c30b7d785e51a614e455c0db4c738a44.pngimage.thumb.png.6cf64919c2d5dbb93dd899602482029d.png
It is the room ceiling heights on level 1.
Glenn, I checked ceiling heights and all are correct. All house, porches and garage are to be 121 1/8".  Note that the front porch is the same structure as the rear porch but it does not exhibit the same issue.
Rob, I shut off the "No room definition" on the garage back attic wall, leaving the "Attic wall" and "No locate" options selected.  That resolved the issue.  Thanks!
Will send on to the client now.
This appears to be an issue with the software but it does have a simple workaround.
Thanks all!
    29346
    schaeffjax
    schaeffjax
