RobUSMC Posted July 24, 2020 Share Posted July 24, 2020 I have a small project. A client already has a backyard gazebo with open rafters with T&G decking. He wants me to build a small work shop behind the gazebo and extends the gazebo roof over the shop so all matches. There will be 36" between the gazebo and the shop that he wants the roof to cover to create a walkway and a place to have his pool cleaning equipment. Ive drawn the gazebo and the shed and just drug the roof planes from the gazebo over the new shop. The shop will have a vaulted ceiling to match the gazebo but I don't want the T&G wood ceiling. I just want drywall. Is there a way to have two separate materials on the same roof plan? Or do I need to have two separate roof planes... One for the gazebo and covered walkway and one for the shop then connect them. Link to comment Share on other sites More sharing options...
HumbleChief Posted July 24, 2020 Share Posted July 24, 2020 10 minutes ago, RobUSMC said: Or do I need to have two separate roof planes... One for the gazebo and covered walkway and one for the shop then connect them. ^^^this. Or maybe a separate ceiling plane for the drywall ceiling? Link to comment Share on other sites More sharing options...
Ridge_Runner Posted July 24, 2020 Share Posted July 24, 2020 2 hours ago, HumbleChief said: Or maybe a separate ceiling plane for the drywall ceiling? Would be my first choice. Link to comment Share on other sites More sharing options...
RobUSMC Posted July 25, 2020 Author Share Posted July 25, 2020 Thanks. Link to comment Share on other sites More sharing options...
CAmichael240114 Posted July 25, 2020 Share Posted July 25, 2020 Use two roof planes the same pitch and structure butting up to each other. Select and change the ceiling finish in each roof plane as required Link to comment Share on other sites More sharing options...
Kbird1 Posted July 26, 2020 Share Posted July 26, 2020 You may also be able to use the Room's Use Soffit Surface for Ceiling Setting for the T&G area...... Wall of Workshop made invisible here ( see Floor ) Link to comment Share on other sites More sharing options...
RobUSMC Posted July 26, 2020 Author Share Posted July 26, 2020 Thanks Link to comment Share on other sites More sharing options...
