Christina_Girerd Posted July 11, 2020 Share Posted July 11, 2020 I have noticed this for a long time, but usually been too busy to ask about it. Anyone know why the movement of an object, such as a text box, using the "select" then tap the "down arrow" on the keyboard method would not work when they are no obvious items in its path? For months, I have noticed this issue, particularly in my Layout file when I'm adjusting text boxes. In the example below, I did a wide selection of the area to show that there are no other objects immediately below the text items circled in red. I can select and use the up arrow and both those text boxes move. Yet not for the down arrow in this instance. I like to use the keyboard arrows for small movements because it is precise and quicker than opening the Transform dbx to move it a specific amount. Another "oddity" is that I can move the left text box (Bldg Coverage) with the left arrow key, but then I can't move it back with the right. As if it hit some invisible buffer, though I'm just moving it back to where it was. I don't know if this is an issue with the latest release, but I don't remember having so many issues with the arrow keys in the past. Is there any key I can press while using the arrow keys that while override whatever Chief thinks the object is bumping against? I tried Ctrl, Alt, and a few others but didn't find anything. Or suggestions about why the arrow keys are behaving as if blocked? Link to comment Share on other sites More sharing options...
Christina_Girerd Posted July 12, 2020 Author Share Posted July 12, 2020 Here it is... So the text that I circled above, will go down about 4 "down arrow clicks" now, but then stops. At least when I just tried it. 2020 07 Sample Existing.layout Link to comment Share on other sites More sharing options...
Chopsaw Posted July 12, 2020 Share Posted July 12, 2020 (edited) 43 minutes ago, Christina_Girerd said: So the text that I circled above, will go down about 4 "down arrow clicks" now, but then stops. At least when I just tried it. Seems fine here. Low batteries in your keyboard maybe ? Edited July 12, 2020 by Chopsaw Sorry I forgot that I had Bumping turned off. Same results as Eric here. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 12, 2020 Share Posted July 12, 2020 You're being limited by CAD items on other pages. I would consider this a bug that you might want to report. Link to comment Share on other sites More sharing options...
Christina_Girerd Posted July 12, 2020 Author Share Posted July 12, 2020 Interesting clip Eric, thanks. How do you get those "ghost items" to be colored and show like that? Are those items from other pages that Michael was referring to? After Michael's comment, I deleted all the other pages, and then the movement worked just fine. Thanks. I'll put in a bug report. Link to comment Share on other sites More sharing options...
Christina_Girerd Posted July 12, 2020 Author Share Posted July 12, 2020 I put in the report and mentioned the comments. When I drag the boxes down, I don't get anything else colored. I also tried this in a generic blank layout (one of Chiefs), putting a text box on one page and another lower down on a second page, but at least in that very quick test, could not get it to reproduce. Link to comment Share on other sites More sharing options...
glennw Posted July 12, 2020 Share Posted July 12, 2020 A quick fix is to select those text boxes on Page 1, and on the Line Style panel, uncheck Bumping>Cad Stops Move. 1 Link to comment Share on other sites More sharing options...
Christina_Girerd Posted July 13, 2020 Author Share Posted July 13, 2020 Good tip - thanks Glenn. Link to comment Share on other sites More sharing options...
