BeachHouse1 Posted July 2, 2020 Share Posted July 2, 2020 Good Morning, In several videos I have seen a dropdown in the toolbar that allows selecting the Dimension Style. I believe it shows the "Saved Dimension Defaults". i can't find it, nor can I find a way to add it. Thanks, Link to comment Share on other sites More sharing options...
tommy1 Posted July 2, 2020 Share Posted July 2, 2020 Joe, please call me if you like. I might have a job for you in Galveston. 832-754-6160 1 Link to comment Share on other sites More sharing options...
Dermot Posted July 2, 2020 Share Posted July 2, 2020 You can find it in the customize toolbars dialog under Active Dimension Defaults Control. Personally, I would recommend that you use the Active Defaults tool instead because it allows you quick access to all of your current defaults in one place. Or you could use the Edit Active View tool that allows you to change the current defaults along with any other view specific data. 1 1 Link to comment Share on other sites More sharing options...
BeachHouse1 Posted July 2, 2020 Author Share Posted July 2, 2020 Thanks Dermont, All squared away. Your answer led me to some videos on customizing the toolbar. The proper names you supplied made the difference. Link to comment Share on other sites More sharing options...
BeachHouse1 Posted July 2, 2020 Author Share Posted July 2, 2020 46 minutes ago, tommy1 said: Joe, please call me if you like. I might have a job for you in Galveston. 832-754-6160 Thank you Tommy Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 2, 2020 Share Posted July 2, 2020 1 hour ago, Dermot said: You can find it in the customize toolbars dialog under Active Dimension Defaults Control. Personally, I would recommend that you use the Active Defaults tool instead because it allows you quick access to all of your current defaults in one place. Or you could use the Edit Active View tool that allows you to change the current defaults along with any other view specific data. Finally, I get to disagree with you(though only partially). I fully agree with the methodology of coaching users to use the active default tools, especially when they are all struggling to transition to SPV's, however, I have an incredibly powerful workflow for dimensioning where I switch my active dimension defaults depending on what I am planning on dimensioning, especially when I am in other user's plans that do not have defaults setup like I do. I have dimension defaults for cabinets only, windows only, walls only, CAD only, 3 inch scale, etc and it is so easy for me to switch on the fly. I wouldn't have it any other way. Link to comment Share on other sites More sharing options...
stephenbc Posted July 2, 2020 Share Posted July 2, 2020 2 hours ago, Renerabbitt said: Finally, I get to disagree with you(though only partially). I fully agree with the methodology of coaching users to use the active default tools, especially when they are all struggling to transition to SPV's, however, I have an incredibly powerful workflow for dimensioning where I switch my active dimension defaults depending on what I am planning on dimensioning, especially when I am in other user's plans that do not have defaults setup like I do. I have dimension defaults for cabinets only, windows only, walls only, CAD only, 3 inch scale, etc and it is so easy for me to switch on the fly. I wouldn't have it any other way. Would you have time to explain your workflow and setup with a video? If not, no worries. 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 2, 2020 Share Posted July 2, 2020 10 minutes ago, stephenbc said: Would you have time to explain your workflow and setup with a video? If not, no worries. This link will expire but it's a video I made for someone going over something very similarhttps://1drv.ms/v/s!AkMNWqmV-cPLgbg0G39v5eXhyjIAXA?e=GuqhUa 1 Link to comment Share on other sites More sharing options...
stephenbc Posted July 2, 2020 Share Posted July 2, 2020 Nice! That is quite an efficient set up. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted July 2, 2020 Share Posted July 2, 2020 2 hours ago, Renerabbitt said: I have an incredibly powerful workflow for dimensioning where I switch my active dimension defaults depending on what I am planning on dimensioning, especially when I am in other user's plans that do not have defaults setup like I do. I have dimension defaults for cabinets only, windows only, walls only, CAD only, 3 inch scale, etc and it is so easy for me to switch on the fly. I wouldn't have it any other way. Hey, Rene. I am always impressed by your ability to get soooo much more out of this software than I. But, like most things CA, your workflow would be a "disaster" applied to mine. The SPV's are a tremendous time saver for me, especially because of the saved defaults. With my aging memory I would totally destroy a set of plans if I was always changing defaults "on the fly." But, to each his own. Thanks for all of your valuable input of how you use this software. Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 2, 2020 Share Posted July 2, 2020 3 hours ago, Ridge_Runner said: The SPV's are a tremendous time saver for me, especially because of the saved defaults I made a video better explaining this process, thanks for the compliment EDIT:audio came out terrible! 200702-20.mp4 Link to comment Share on other sites More sharing options...
Ridge_Runner Posted July 3, 2020 Share Posted July 3, 2020 2 hours ago, Renerabbitt said: I made a video better explaining this process Interesting workflow, Rene. I can certainly see how you can save some valuable time using your system. Thanks for explaining the "working view;" that seems to tie everything together well. I also use a "working plan view" but usually only add things like dimensions as temporary dims during the design phase. If I add them too soon I will almost always have to move them around for condocs which takes even more time. The exterior dims I usually do auto after deleting any temp dims. Interior dims are another story altogether. Thanks again. Link to comment Share on other sites More sharing options...
