SMC2992 Posted May 29, 2020 Share Posted May 29, 2020 Hi Friends, I was creating a glass wall and wanted to put some sort of frosting using wall covering, but that does not (naturally) continue on the glass slab door, Is there a way to do that? Sample plan attached Sample glass partition.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 29, 2020 Share Posted May 29, 2020 A "Wall Covering" is for walls, and not doors. For a door you could use a custom back-splash carrying a custom .png based material. I think you need to communicate exactly what kind or sort of "Frosted" look that you are trying to achieve for others to offer a precise solution, how is it supposed to look, find an existing photo or example so those who would wish to help you then can. DJP Link to comment Share on other sites More sharing options...
SMC2992 Posted May 29, 2020 Author Share Posted May 29, 2020 Thank you David for quick response, for this I have attached a sample plan. I have attached again Sample glass partition.plan Link to comment Share on other sites More sharing options...
robdyck Posted May 29, 2020 Share Posted May 29, 2020 You have a few options, but you might not like any of them! use a polyline solid on the doors to match the frosted wallcovering (this won't 'move' with the doors) make a door symbol out of solids that match the frosted wall covering. (this won't be simple to adjust the pattern vertically if you decide to adjust the frosted wall covering) I'd use option 1 until I know the design is finalized. Check out the attached plan. Sample glass partition.plan Link to comment Share on other sites More sharing options...
DzinEye Posted May 29, 2020 Share Posted May 29, 2020 Using CAD detail from view makes it pretty quick to make... as long as you leave the glass pattern as it is Striped Glass Door.calibz Link to comment Share on other sites More sharing options...
