FahmiSyarif Posted May 21, 2020 Share Posted May 21, 2020 Hi Chiefs, I draw using X12, how can I close the hole under the railing in the picture? Link to comment Share on other sites More sharing options...
Kbird1 Posted May 21, 2020 Share Posted May 21, 2020 did you use an invisible Wall there ? M. Link to comment Share on other sites More sharing options...
FahmiSyarif Posted May 21, 2020 Author Share Posted May 21, 2020 (edited) There is no invisible wall there here is the second floor plan view. there is only railing there. in this is the first floor Edited May 21, 2020 by FahmiSyarif double image Link to comment Share on other sites More sharing options...
Kbird1 Posted May 21, 2020 Share Posted May 21, 2020 2 minutes ago, FahmiSyarif said: there is only railing there There is no railing in 3D, are you sure the invisible checkbox isn't checked for the railing? Another issue would be not displaying the balcony framing perhaps ie the floor structure in 3D Always best to post the Plan file but make sure it it close in Chief when you attach it to a Forum post. please do you Forum signature at some point to please , some answer depend on the Version used etc , so that info can be important. M. Link to comment Share on other sites More sharing options...
DzinEye Posted May 21, 2020 Share Posted May 21, 2020 As Mick said... if you show framing there will no longer be a hole there..... BUT...You need to have a roof or something over the front of the garage, even if the deck does not cover that part. Build your roof and problem solved. Link to comment Share on other sites More sharing options...
javatom Posted May 21, 2020 Share Posted May 21, 2020 You can also cover it with a molding. In the real world, this would have some sort of trim board covering the edge. The molding would accomplish that look. The down side is that it would have to be moved if you moved the wall above it. Link to comment Share on other sites More sharing options...
FahmiSyarif Posted May 21, 2020 Author Share Posted May 21, 2020 thank you guys for the respon. When I build the roof, the hole can be seen. If you have time, to review, I post my plan. rumah03.plan Link to comment Share on other sites More sharing options...
FahmiSyarif Posted May 21, 2020 Author Share Posted May 21, 2020 18 minutes ago, Kbird1 said: There is no railing in 3D, are you sure the invisible checkbox isn't checked for the railing? There is, it is a glass panel. Link to comment Share on other sites More sharing options...
DzinEye Posted May 21, 2020 Share Posted May 21, 2020 1 hour ago, FahmiSyarif said: thank you guys for the respon. When I build the roof, the hole can be seen. If you have time, to review, I post my plan. rumah03.plan Change the railing on the end from 'Interior Railing, Copy' to your 'Interior Railing' wall type Link to comment Share on other sites More sharing options...
DzinEye Posted May 21, 2020 Share Posted May 21, 2020 Really though, you should have an exterior rail type that finishes with exterior materials Link to comment Share on other sites More sharing options...
Chrisb222 Posted May 21, 2020 Share Posted May 21, 2020 As Mark said, changing to the other Interior Railing wall type works, but just to explain why the Copy doesn't work, look at this picture: When you "Build Platform" to the outermost wall layer, that outer wall layer material can no longer extend down to cover over the platform space. Since you have no platform built yet, you see nothing, because the platform is interfering with the wall layer material. The other Railing wall type works because it's set to build platform to the Main layer, "Fir Stud." Link to comment Share on other sites More sharing options...
FahmiSyarif Posted May 21, 2020 Author Share Posted May 21, 2020 thank you so much guys, it work! Link to comment Share on other sites More sharing options...
FahmiSyarif Posted May 21, 2020 Author Share Posted May 21, 2020 I changed the wall type, then generate the roof. The hole has cover now Link to comment Share on other sites More sharing options...
