Help custom muntins in archtop window
GeneDavis
Need more info Gene...  Can't figure out which window(s) you're talking about and what custom thing you're trying to do with the lites.
I see a grouped set of three double hung with div. lites in the top sash, and a big shaped transom window with no div. lites... maybe you wanted that divided?  Need more info. and pic of what you want to achieve.
5 minutes ago, joey_martin said:
I trimmed the lines back to inside the sash. Maybe that was the issue, not 100% sure, but I did get them to load.
How'd you get the cad lines to show up Joey?   I turned on all layers... nothing.
Yup.  This is the problem.  Chief wants to see them as close as possible to the edge of the glass, but the lines need to be trimmed back so that they're at least inside the sash.
11 minutes ago, joey_martin said:
Used his saved camera view inside the room.
Doh!... I immediately set up a view outside the window, figuring that it where they'd be drawn.  Didn't even notice the inside camera.
