K-Lynn Posted May 14, 2020 Share Posted May 14, 2020 In X11 is there a quick way to show just a roof plan without turning off all the other layers? Link to comment Share on other sites More sharing options...
Chopsaw Posted May 14, 2020 Share Posted May 14, 2020 Sure go to your All Off Layer Set and turn on the layers you need and make a copy of it an call it Roof Plan Set. Or I think there is a Default Roof Plan Layer Set that you could try or modify. Hope that helps. Welcome to the forum. Link to comment Share on other sites More sharing options...
rgardner Posted May 14, 2020 Share Posted May 14, 2020 If you are using the chief template or import the view sets from the standard template there is a Roof framing and a Roof plan saved plan view as well. The "new" way of doing layer set control. Link to comment Share on other sites More sharing options...
tracyswanson Posted January 28, 2021 Share Posted January 28, 2021 Newbie here.... My X12 is not showing a Roof Plan Set in the dropdown... is it not a default? Or do I create that ? Link to comment Share on other sites More sharing options...
Chopsaw Posted January 28, 2021 Share Posted January 28, 2021 If you are just starting out it would likely be best to use an X12 template plan which has those as Ryan said. Look here to be sure you are using the latest version: C:\Program Files\Chief Architect\Chief Architect Premier X12 (64 bit)\Templates Link to comment Share on other sites More sharing options...
Michael_Gia Posted January 28, 2021 Share Posted January 28, 2021 In the Project Browser of the X12 Residential Template Plan. Link to comment Share on other sites More sharing options...
