jmsisco Posted May 6, 2020 Share Posted May 6, 2020 There is a stray 2nd story wall I am unable to delete on the attached plan. When I select the wall to delete it, the wall changes to a invisible wall and then back to a regular wall when I try to delete the invisible wall. What am I missing? stray wall.zip Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 6, 2020 Share Posted May 6, 2020 open the walls dbx and uncheck attic wall then delete it or turn off attic walls Link to comment Share on other sites More sharing options...
jmsisco Posted May 6, 2020 Author Share Posted May 6, 2020 Hi Perry, I've tried that but it will not delete. I have selected and unchecked attic walls. There seems to be some kind of weird loop going on. Link to comment Share on other sites More sharing options...
rgardner Posted May 6, 2020 Share Posted May 6, 2020 Check your foundation level to see if you have a foundation wall there? Glass house also helps check weird items like this. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 6, 2020 Share Posted May 6, 2020 THAT WALL MIGHT BE REGENERATING automatically with auto attic walls turned on, you might not want to delete it just turn attic walls off in final view sent to the layout. Link to comment Share on other sites More sharing options...
jmsisco Posted May 6, 2020 Author Share Posted May 6, 2020 It is not showing in any of the 3D views and there is no attic for that part of the home. Very strange I'm guessing it is a program glitch. I have sent it in to support. Maybe they can tell me what is going on. Link to comment Share on other sites More sharing options...
jmsisco Posted May 6, 2020 Author Share Posted May 6, 2020 Eric, Thanks for finding that! I'm not sure how that got unchecked. The person who created the plan claims they did not turn that off. Strange it was only that one wall Appreciate the look! Link to comment Share on other sites More sharing options...
DzinEye Posted May 6, 2020 Share Posted May 6, 2020 Here's that attic wall. Just a thin layer is why you're not seeing it. Note the difference in both sides of the garage. Link to comment Share on other sites More sharing options...
jmsisco Posted June 19, 2020 Author Share Posted June 19, 2020 Thanks again for the tip. This software has changed so much over the last 10-15 years it is hard to keep up with it Link to comment Share on other sites More sharing options...
