Building Monolithic Slab or Stem Wall Dialog
ChiefMikla
Every so often this dialog will pop up and never close.  The bar gets to about 90% and just hangs and I have to manually cancel it.  I am not even sure why it is popping up.  It even happens when I am making a simple symbol change or delete.  Any ideas?
Thanks!
55 minutes ago, ChiefMikla said:
Only appears to happen in this plan.
Likely something has been corrupted or chief is unsure how to complete the task required.  Most likely having something to do with the monolithic slab or stem wall.
Post the plan.  I am sure that someone will be bored enough to figure it out.  Nothing like being suck at home. :rolleyes:
