Framing sticking through roof
Hammer7
Obviously you built framing and then changed your mind and edited the roof without building framing a new after you changed the roof. Just order framing to be built again and then all will be well. The software only does what you tell it to do when you tell it.
And the reason is shows in some views as opposed to others is controlled by layer settings for each view (Display Options).
For elevation views, you might want to setup a layer set that does not show framing. Then save and name those views.
