Is anyone using MS Surface machine with x12 ? Do you get good speed and graphics rendering?
Thanks,
Chad
Thanks,
Chad
I am using Surface Pro 4-i7. Have been for several years.  Haven't done anything in X12 yet, but have opened a couple of plans haven't seen much difference in speed on my SP yet.  A lot is going to depend on the complexity of the plan and other nuances that take place, as you develop a plan.  3D views have been a bit slow at times (X11) but again it was as much related to the complexity I believe vs the age of my SP. This isn't much help, if you're thinking of going to a Surface Pro, I'm sure the newer ones will do the job.
I would recommend that you might be best to only consider the Surface Book as this is available with a discrete NVidia graphics card. All other Surface models are only available with the Intel integrated graphics chip.  Though this chip seems to work I have found things to be glitchy, especially if you are PBR'ing and it is definitely a lot slower than a dedicated graphics card.
I had a Surface Pro, it was ok for on-site field work,  etc. but with the small screen, a secondary monitor is a necessity. It also didn't handle larger models very well.
I have a Surface Pro 6 - i7 w/16 GB RAM. For everything except rendering it's great. If you can stick to vector views, it's very fast. As mentioned above, for regular work, you will want a larger secondary monitor. It can do rendering just fine, but nowhere close to a dedicated graphics card.
Hi Richard,
Thanks for the information. Let me ask? When you say rendering do you mean doing like a ray trace or just poping up a full over view and do the overviews rotate OK?
Chad
I guess that was a little imprecise. I was referring to any view that is using OpenGL. There is a significantly longer delay with the initial generation, but after the view generates, you can spin it just fine.
    28603
    jerryajohnson35
    jerryajohnson35
  • Similar Content
    • By marie-eve
      I have a MacBook Pro but can’t use my ex10 version on it it crash all the time, I would like to buy a new laptop for version x12 any suggestion for a long road ?
      I know the MacBook Pro next generation will be out of only next year...
    • By carowe
      I just bought a new desktop and two 27” monitors in December and last week signed a contract on a job out of state that will require quite a bit of travel.  I am going to have to get a new laptop but really don’t want to spend a fortune at this point and don’t want to have to buy another license.  Most of my work will be done in my office, but on my trips out there will need to access my CA files, and perhaps work on them. What would be the minimum requirements I would need in order to access my main computer and let it do the heavy lifting on CA?  I use X11 Interiors and will primarily be working on kitchen and bathroom designs for the architect.
    • By PvdPol
      Dear all,
      I'm new to the forums and i've tried to find my way in the already existing topics, such as
      - https://www.chiefarchitect.com/products/sysreq.html
      - https://chieftalk.chiefarchitect.com/topic/21934-hardware-recommendations/?tab=comments#comment-179153
      I could not find an answer yet, hopefully some of you can help me out.
      I am currently struggling with Chief Architect Premier, ray traces are really slow at 1080P (1 pass takes like 15-30 min)
      Also working for in PBR is making my system really really slow and it is getting frustrating.
      My model is not complex and I think I need an hardware upgrade.
      Current machine (Notebook - April 2014)
      X•BOOK 15CL56 NVIDIA GTX770m 3GB, Full HD (+/- 20000 3DMARK) Intel® CoreTM i7-4710MQ (6M Cache, up to 3.50 GHz) - 47Watt (Quadcore) 16GB DDR3L (1600MHz)
        New system specifications (not bought yet)
      AMD Ryzen 7 3700X Boxed MSI X470 Gaming Plus Max Crucial Ballistix Sport LT BLS2K16G4D30AESB  (32GB Ram) Intel 660p 1TB Solidstate drive Graphic card? Nvidia? Any Advice?
      I think the 32 GB of memory is already an overkill, not sure if this is needed.
      But I'm mostly wondering regarding the choice of CPU and Graphics card
      Is this a good setup? What kind of performance improvements can I expect? What would be your advice?
      Thank you!
      Regards,
      Peter
    • By winglakedesign
      Hello everyone,
      I am about to purchase a new MacBook Pro.  Mine current MacBook Pro is  2015, Intel Core i5, 2.9 GHz, 8 GB MHz, Intel Iris Graphcs 6100 1536 MB.  Whatever all that means....I get the swirling rainbow often because I run Affinity Photo and Home Designer Architectural along with a few other things being open at the same time...mail, messages, etc.
      So - time to upgrade.  I don't know which is more important to help run programs quickly - Obviously - I would like the upgrades on all - but it's already so expensive so wondering if the combination of standard and some upgrade will be okay.  I have  design business and use Chief Architecture for floor plan and furniture layouts to present to clients.
      1) 2.6GHz 6‑core 8th‑generation Intel Core i7 processor, Turbo Boost up to 4.3GHz (standard)  vs
      2.9GHz 6‑core 8th‑generation Intel Core i9 processor, Turbo Boost up to 4.8GHz
      2) 16GB 2400MHz DDR4 (standards)  memory vs.
      32GB 2400MHz DDR4 memory
      3) Radeon Pro 560X with 4GB of GDDR5 memory (standard) vs
      Radeon Pro Vega 16 with 4GB of HBM2 memory vs
      Radeon Pro Vega 20 with 4GB of HBM2 memory
      I was originally thinking of doing the upgrade to the i9 intel processor - only but then someone mentioned upgrading the graphics card.
      I am sticking with Mac at this time because it's what I know.  Can anyone advise please?  Thank you so much!
    • By AnotherCADUser
      I've been getting into the rendering and video side of CA. I've been using a Mac with 12gb shared ram, which is ok, but you can see it's not great, esp the frame rate. I want to really get into it with clients so I'm going to get X10 and my son said it should be smooth as with this machine. What do you think?
      https://www.dell.com/en-au/shop/dell-laptops/new-inspiron-15-7000-gaming-laptop/spd/inspiron-15-7577-laptop/a511070au
