Missing drywall
builtright3
15 minutes ago, DRAWZILLA said:
Looks to me like you could use a shelf ceiling there/. if you used walls for that fireplace, it becomes a room
How do I do that because it wont select as a room?
I tried to post the plan but forgot the procedure to do that.
Thank you Perry, I figured it out. I just made it a room rather than to have one wall up against the other.
Capture.thumb.PNG.e6671b5f359b01b6b4f1d8e84e890c93.PNGCapture2.thumb.PNG.b764f8054ae2e3b01e2d394e2b6f575b.PNG
10 minutes ago, robdyck said:
To prevent a ceiling plane from being cut by walls, you'll need to uncheck "use room ceiling finish"
The reason I was having the problem was because I had one wall placed against the other so I didn't have the options for room definition. So I moved my wall out and made a room so I had the option and then it was fine.
Thank you for your response.
