Joe_Carrick Posted March 11, 2020 Share Posted March 11, 2020 NVidea RTX Graphic Cards can handle Ray Tracing in Real Time. Does this work in Chief or is Chief's Ray Tracing limited to using the CPU? Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted March 11, 2020 Share Posted March 11, 2020 It's my understanding that CA's Raytrace can't utilize this new RTX raytracing feature. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 12, 2020 Author Share Posted March 12, 2020 2 hours ago, TheKitchenAbode said: It's my understanding that CA's Raytrace can't utilize this new RTX raytracing feature. bummer !!! Link to comment Share on other sites More sharing options...
tommy1 Posted March 12, 2020 Share Posted March 12, 2020 My new laptop has this feature and my raytracing is a lot faster than what I used to have but probably not due to the RTX card. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted March 12, 2020 Share Posted March 12, 2020 2 minutes ago, tommy1 said: My new laptop has this feature and my raytracing is a lot faster than what I used to have but probably not due to the RTX card. The improvement you are seeing will be due to your CPU's higher core count. With CA's Raytrace if you double the cores the time to trace will be cut in half. To take advantage of the RTX cards built-in raytrace requires the rendering program to be specifically programmed. There's likely lots of future potential here but even the gamming industry which this was designed for is slow in changing over to this. Link to comment Share on other sites More sharing options...
gelbuilding Posted March 12, 2020 Share Posted March 12, 2020 Hi Joe, Try 5D render you will be very impressed, especially with that GPU Link to comment Share on other sites More sharing options...
