Christina_Girerd Posted February 28, 2020 Share Posted February 28, 2020 Did the Point to Point Resize tool change in the update? I was trying to use it tonight and don't remember having it only let you resize in exactly horizontal or vertical. I'm trying to adjust one side of a parcel map image. I first tried to resize the image as I brought it into Chief - the blue rectangle in the image, and found out I couldn't use the pt to pt tool between the two property corners because it wasn't horizontal or vertical. So then I rotated the image - the yellow rectangle - and tried to use the pt to pt tool again. This time I could snap between the two corners, but the dimensions would not come out accurately. I was trying to set the distance between the circled corners of the yellow rectangle to 80' so I entered that in the pt to pt resize dbx, but the result measures out to about 88' 5". I tried this multiple times and do not get accurate results. My guess is that it is some issue with the image being rotated. Anything I am missing? Link to comment Share on other sites More sharing options...
Chiefer Posted February 28, 2020 Share Posted February 28, 2020 I did not update yet,,,point to point works with horizontal and vertical only. Link to comment Share on other sites More sharing options...
robdyck Posted February 28, 2020 Share Posted February 28, 2020 I do believe this has changed. I could be wrong but I'm pretty sure I've used this tool on any angle in the past. The new function already got me planning a house wrong! For a quick lot size, I'll screen grab the lot from a pdf, then use that tool to size the lot close enough for planning. I used it on the angle and noticed pretty quick my lot was too big. I'd like to know from Chief if this has changed. Holding control while using it doesn't change anything. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 28, 2020 Share Posted February 28, 2020 It has always worked on vertical and horizontal only. It continues to work the same. 2 Link to comment Share on other sites More sharing options...
robdyck Posted February 28, 2020 Share Posted February 28, 2020 26 minutes ago, Alaskan_Son said: It has always worked on vertical and horizontal only. It continues to work the same. Oh Crap. Pretty sure I've planned several homes using that method so they're either too big or too small! Actually, for angled lines on images I usually use a cad line's length as my reference and rescale from that. Link to comment Share on other sites More sharing options...
Christina_Girerd Posted February 28, 2020 Author Share Posted February 28, 2020 I went back to using a CAD line to scale for this one too. I checked X11 and yep, it only showed it working horizontal or vertical, but I really thought I had used it on angles at some time. I wonder why they don't let it be used on other angles? As that would sure be useful in cases like this angled parcel map. I will submit a request that. And a bug report for the scale differences issue. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 29, 2020 Share Posted February 29, 2020 Here's the method I would recommend... Draw a CAD line depicting your desired reference line. Now rotate that CAD line so it's perfectly parendicular. Now select the image and do the Pt. to Pt. Resize using your CAD line. Link to comment Share on other sites More sharing options...
glennw Posted February 29, 2020 Share Posted February 29, 2020 13 hours ago, Alaskan_Son said: It has always worked on vertical and horizontal only. It continues to work the same. There is one case I know of when this is not correct. That is when you have an image that you want to resize (rotated or ortho) using the images perimeter (as opposed to click any points within the image). You can resize the image by clicking the Point To Point Resize in one corner of the image. You can then drag the cursor along the image edge to the other corner - the cursor will stick to the image edge, no matter what the angle. Click the second corner and the dbx will open. Although this works, there are probably easier ways to resize the image like using it's dbx. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 29, 2020 Share Posted February 29, 2020 1 hour ago, glennw said: There is one case I know of when this is not correct. That is when you have an image that you want to resize (rotated or ortho) using the images perimeter (as opposed to click any points within the image). You can resize the image by clicking the Point To Point Resize in one corner of the image. You can then drag the cursor along the image edge to the other corner - the cursor will stick to the image edge, no matter what the angle. Click the second corner and the dbx will open. Although this works, there are probably easier ways to resize the image like using it's dbx. I probably should have clarified, but I forgot. There’s an important distinction. Its always horizontal and vertical relative to the image. Link to comment Share on other sites More sharing options...
MORTY1954 Posted March 13, 2020 Share Posted March 13, 2020 The Point to Point resize tool does not work like it did in X11. I had a known dimension both horizontally and vertically. I would resize in the horizontal direction and it would resize to the dimension I wanted. Then I resized vertically and it did change the vertical direction but changed the horizontal direction as well. I need to stretch the document. It is working like the Transform/replicate object resize function. Before the Point to Point would stretch my document only in one direction at a time. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 13, 2020 Share Posted March 13, 2020 4 minutes ago, MORTY1954 said: The Point to Point resize tool does not work like it did in X11. I had a known dimension both horizontally and vertically. I would resize in the horizontal direction and it would resize to the dimension I wanted. Then I resized vertically and it did change the vertical direction but changed the horizontal direction as well. I need to stretch the document. It is working like the Transform/replicate object resize function. Before the Point to Point would stretch my document only in one direction at a time. You need to uncheck this new setting... 1 Link to comment Share on other sites More sharing options...
MORTY1954 Posted March 13, 2020 Share Posted March 13, 2020 Thanks for the response. I feel like DUH! I should have noticed that was checked. Thanks again. 1 Link to comment Share on other sites More sharing options...
