Does anyone know how to get a 24" ht house floor off grade to sit on the Terran? they are going to build the dirt up to raise the slab I have never done this.
I would appreciate any help
I would apprecaite you help.
Newell Cheatheam
CA 11
raised slab issue.pdf
Richie house. La.zip
One simple method...
Create an elevation polyline that is the perimeter of the lot.
Create an elevation polyline that is the perimeter of the structure. Make this elevation polyline 24" higher than the previous one.
Same concept set your above terrain to zero and set a poly line on the outside at -24”
Make your terrain larger east/west
Use house exterior room, make room polyline, offset 4" so you can see it.
Convert to terrain elevation line, set to 20" Falt interior.
Offset this line 4', change to no flat
Offset the new line 6' change to 15"
Turn on rebuild terrain for this exercise.
    27648
    DarrinKoone
    DarrinKoone
