capitaldesigns Posted December 29, 2019 Share Posted December 29, 2019 I'm trying to get a conc. fill pattern in my new footings to show up on the foundation plan without success. I've added a screen shot of the foundation plan, wall type definitions, footing specification and layer fill style. I thought it added the fill correctly, but apparently I did not. Can someone let me know why the fill pattern is not showing up in the foundation plan. Thank you, Mike Link to comment Share on other sites More sharing options...
capitaldesigns Posted December 29, 2019 Author Share Posted December 29, 2019 Were are you seeing the 6" concrete wall ? Link to comment Share on other sites More sharing options...
capitaldesigns Posted December 29, 2019 Author Share Posted December 29, 2019 I already have it called out as a 12" wide concrete stem wall. Is there some other setting in the program that is not letting the conc. fill pattern show on the foundation plan ? Link to comment Share on other sites More sharing options...
capitaldesigns Posted December 29, 2019 Author Share Posted December 29, 2019 This was an automatic foundation using the build foundation tool. This is not a new problem. The only area that I can get the fill pattern to show up in the foundation plan is the garage stem wall. I also tried the straight foundation wall and the slab footing under the wall pull down menu. Still no fill pattern. Link to comment Share on other sites More sharing options...
capitaldesigns Posted December 29, 2019 Author Share Posted December 29, 2019 I just noticed that if I cut the footing in the middle of the wall and pull the footing apart by a foot or so the fill pattern shows up. When I connect the footings together again the fill pattern again disappears. Any ideas why this is happening ? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 29, 2019 Share Posted December 29, 2019 Yes. It’s because you’re working with a monolithic slab and are using the Slab Footing tool. That’s how it works. Away from my computer now, but it feels like there’s a way to force what you want. I don’t recall for sure, but when the walls close up to form the slab, did they change to invisible walls? If so, try changing them back to visible and see what that does. Either that or maybe play with the settings on the foundation tab. I think for example that changing from a Monolithic Slab will also fix your problem but you’ll lose the angled footing edge. Link to comment Share on other sites More sharing options...
capitaldesigns Posted December 29, 2019 Author Share Posted December 29, 2019 When I pulled apart the footings both the line for the outside slab and the inside footing lines both turned to solid lines. When I joined them together the inside footing line changed into a dashed line and the outside slab line remained solid as it should be. The walls did not change to invisible walls. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 29, 2019 Share Posted December 29, 2019 On 12/28/2019 at 8:32 PM, capitaldesigns said: When I pulled apart the footings both the line for the outside slab and the inside footing lines both turned to solid lines. When I joined them together the inside footing line changed into a dashed line and the outside slab line remained solid as it should be. The walls did not change to invisible walls. I just stopped back into the office for a moment and it looks like there's essentially only 2 ways to force those walls to display as solid if you're using them to define a monolithic slab and they both come at a cost... 1. Uncheck Foundation Wall. This would require that none of the walls defining your mono slab area be set to a Foundation Wall though, and they would all get their footing definition from the Default Slab Footing Wall definition. 2. You change the room definition to remove the Monolithic Slab designation. You would lose your beveled footing shape though. and would have to join your auto fills in section views to get one solid slab/footing (you could add the beveled shape when you do this though.) There may be other ways and there may be other downsides to those 2 methods, but I think that's about it. P.S. You could also just add the fills with CAD. Link to comment Share on other sites More sharing options...
glennw Posted December 29, 2019 Share Posted December 29, 2019 Open the foundation "room" and go to the 1 hour ago, capitaldesigns said: When I pulled apart the footings both the line for the outside slab and the inside footing lines both turned to solid lines. When I joined them together the inside footing line changed into a dashed line and the outside slab line remained solid as it should be. This is caused by the way Chief has chosen to implement mono slabs. There is a foundation room that is enclosed by walls that really don't have any height, but they define where the footing (thickened slab edge) goes. When you break the walls, you break the room definition. It is no longer a mono slab and so the walls show as normal walls not mono slab footing walls. I think that because there is really no wall displaying in plan, there is nothing to hatch. Try this to solve your hatch problem. Open the dbx for the foundation room. On the Structure panel, go to the Relative Heights section and change the Floor To SWT to 1mm (or the smallest that will take). This will show the hatch for the foundation wall, but it will also probably cause some other problems like drop your floor by 1mm, increase your ceiling heights by 1mm....... It cannot be seen in cross section. In my opinion, forget the hatching, or use cad. Link to comment Share on other sites More sharing options...
capitaldesigns Posted December 30, 2019 Author Share Posted December 30, 2019 I tried raising and lowering the SWT by " and I still do net get the hatch pattern to show up. Most of my residential projects are remodel and additions. The building departments require us to show a hatch pattern on the new footings. It looks like I will need add the hatch patterns manually. Thank you for the help. Mike Link to comment Share on other sites More sharing options...
Kbird1 Posted December 30, 2019 Share Posted December 30, 2019 51 minutes ago, capitaldesigns said: I tried raising and lowering the SWT by " and I still do net get the hatch pattern to show up. Most of my residential projects are remodel and additions. The building departments require us to show a hatch pattern on the new footings. It looks like I will need add the hatch patterns manually. Thank you for the help. Mike You can model the monoslab yourself , the same way chief does it automatically actually, using a 12 " Concrete Stem Wall with the hang 1st Floor inside foundation setting and the main floor set to a 4" slab. This is what I sometimes have to do as CA doesn't like to join a monoslab and stemwall foundation much eg for a monoslab garage connected to a Stemwall foundation house. The height and width settings below you will need to change for local needs and construction techniques but this should give you the idea. In cross Section you need to edit the Conc. Auto Detail Polylines ( or delete unneeded ones) to get the Chamfer but all else seems to remain the same or you can use a Room molding polyline to add the chamfer instead .....see last pic , used CA -35 for a down and dirty Chamfer , which I left "bone" so you can see it easier in 3D..... 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 30, 2019 Share Posted December 30, 2019 23 hours ago, Alaskan_Son said: I just stopped back into the office for a moment and it looks like there's essentially only 2 ways to force those walls to display as solid if you're using them to define a monolithic slab and they both come at a cost... 1. Uncheck Foundation Wall. This would require that none of the walls defining your mono slab area be set to a Foundation Wall though, and they would all get their footing definition from the Default Slab Footing Wall definition. 2. You change the room definition to remove the Monolithic Slab designation. You would lose your beveled footing shape though. and would have to join your auto fills in section views to get one solid slab/footing (you could add the beveled shape when you do this though.) There may be other ways and there may be other downsides to those 2 methods, but I think that's about it. P.S. You could also just add the fills with CAD. Was just chillin' here and it occurred to me that in addition to these and Glenn's extra idea there's also one more option that doesn't actually seem to have any downsides to speak of. At least none that I can think of off the top... Leave the desired walls as slab footings, leave the room as a Mono slab, but change the wall to a Pony Wall. Set the upper wall to be a copy of the Lower wall, but change the material to a copy of the Concrete material with a non-concrete material definition. Chief needs a concrete material to define the mono slab properly but it only hides walls that are defined as concrete... Link to comment Share on other sites More sharing options...
capitaldesigns Posted December 30, 2019 Author Share Posted December 30, 2019 It to bad that CA does not make it easier to hatch footings. When CA draws the garage slab it hatches the stem wall, not the footings. I would thing if CA can hatch the stem wall of the footings it would be able to hatch the footings as well. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 30, 2019 Share Posted December 30, 2019 6 minutes ago, capitaldesigns said: It to bad that CA does not make it easier to hatch footings. When CA draws the garage slab it hatches the stem wall, not the footings. I would thing if CA can hatch the stem wall of the footings it would be able to hatch the footings as well. Honestly never had to do this before (thus the reason for the reason for the somewhat uncertain nature of some of my responses) and my memory may be failing me, but I don’t actually recall having seen it in anyone else’s plans before either. I think Chief just set it up so that it works for the vast majority of users since typically a person wouldn’t want to see if fill. I wouldn’t be opposed to something like a Show Wall Fill In This View toggle though. Link to comment Share on other sites More sharing options...
capitaldesigns Posted December 30, 2019 Author Share Posted December 30, 2019 Most of my project are additions and remodels. The building departments want the new footings to be hatched to distinguish them from the existing footings. We hatch new walls to distinguish them from the existing walls. Same concept. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 30, 2019 Share Posted December 30, 2019 37 minutes ago, capitaldesigns said: Most of my project are additions and remodels. The building departments want the new footings to be hatched to distinguish them from the existing footings. We hatch new walls to distinguish them from the existing walls. Same concept. Ya, I totally get it. Just not too common in my experience. There are other ways to show old vs. new too. Did you try the pony wall method I mentioned to see if that might work for you? I’m kinda curious if it has any other downsides in an average practical application (assumes of course you don’t need to set the wall as a pony wall for other reasons but that would typically be pretty rare for a mono slab in my experience). Link to comment Share on other sites More sharing options...
capitaldesigns Posted December 30, 2019 Author Share Posted December 30, 2019 I did not get a chance to try the pony wall yet. I will try later today. Thanks Link to comment Share on other sites More sharing options...
