Designer100
Wal above courtyard sticcking out
Not sure why its doing it, but if you add a room divider to make the out door are a "room" then uncheck "roof above" and uncheck "ceiling above" (in the dbx), it goes away.
Also, if you line up the wall's main layer with the collinear wall to the top of the screen, things fix themselves.
I took a different approach, noticing that the order of layers was different in the curved wall than the straight wall.  I reversed the straight wall and bingo.  Upper section disappeared.
Wall_Problem_Design.zip
    28444
    Lufunoraf
    Lufunoraf
  • Similar Content
    • By stevenyhof
      I have watched the video of ChiefSkills by Steve Nestor, "DORMERS - Auto and Manual Types"
      Trying to use the idea there to cut my walls out of the living space. I think you called it "Cheek Walls".
      See the real picture and the angled ceiling. That is what I am trying to do.
      Any thoughts?
      SND1823 Klinke Residence.plan
    • By hamedDesighn
      How to fix wall length Or lock the wall dimention so they don't change .
      i would be thankful if somebody help .
    • By TCDLLC
      Hi, I am a Revit user converting to Chief.
      When working with angled walls in Chief, I have not been able to lock a wall from moving when changing dimensions on connecting walls.
      I am familiar with how to use the directional tools to move an end of an object to adjust its dimensions.
      When angled walls are off-angle, I can waste significant time adjusting the lengths of the angled walls and still not achieve the dimensions I need for all connecting walls.
      The use case scenario is when I am drafting a plan using dimensions provided to me to create the build.
      Of course, if I was creating a plan from scratch, I could probably avoid this situation.
      Any suggestions?
    • By MichaelaS
      The wall shown is on the same plane with a false gable roof above only a portion. The wall from the interior will reflect the same ceiling height as the rest of the home, but from the front elevation I would like the wall to be taller to move my gable up. How can this be done in CA as the wall heights are dictated by the room's ceiling height?
    • By StructEng58
      Hello All,
      I am working on a project, which its an addition to a service garage with an apartment above. The problem that I am having is that I need a new wall against an existing in order not to see a hole in the area of the existing wall. As you can see in the image of the second floor plan below where I circled it is where I need to add another wall.
      As you can see from my front elevation. I have a hole in the area where there is no wall.
      I have attached a back-up of plan to this email for reference also. I am open to other suggestions on how to fix this issue.
      Thank you in advance for the help.
      Chris
      RB Garage.zip
