wjmdes Posted November 21, 2019 Share Posted November 21, 2019 Trying to add this piece of crown to the top of the windows. I come across this quite a bit in historic Atlanta and usually end up drawing a piece of molding using a polyline and adjust for each window. I just tried creating a symbol into millwork using a piece of crown. This seemed to work well, but does not wrap on each side. Link to comment Share on other sites More sharing options...
wjmdes Posted November 21, 2019 Author Share Posted November 21, 2019 1 8 minutes ago, solver said: Try a Lintel. A lintel replaces the top piece of casing. Link to comment Share on other sites More sharing options...
wjmdes Posted November 21, 2019 Author Share Posted November 21, 2019 9 minutes ago, solver said: Great, perfect, although it still does not give me a clue how to make it work or do it. When I use a lintel it gets rid of the top casing. Link to comment Share on other sites More sharing options...
wjmdes Posted November 21, 2019 Author Share Posted November 21, 2019 3 minutes ago, solver said: Use a profile that combines the casing and crown. That is what I was afraid of. Unfortunately, when I mull 2 windows I get a bunch of extra vertical lines where the lintels overlap. I think I need to stick to the molding polyline. Link to comment Share on other sites More sharing options...
wjmdes Posted November 21, 2019 Author Share Posted November 21, 2019 5 minutes ago, solver said: I'm not seeing that. You can also apply a lintel to the mulled unit instead of the individuals But you now have extra horizontal lines between vertical and top casing. I know I cannot have everything I want. Mulling a window in Chief changes its appearance graphically. I do appreciate your help though. Thanks. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 21, 2019 Share Posted November 21, 2019 In that case, you should submit a "Feature Request" to have Lintels optionally be above (and in addition to) the casing. Who knows, CA might implement that request - but not if they haven't been asked. Link to comment Share on other sites More sharing options...
SNestor Posted November 21, 2019 Share Posted November 21, 2019 I made you a video...hope it helps! 1 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted November 21, 2019 Share Posted November 21, 2019 Thanks Steve nice one Link to comment Share on other sites More sharing options...
wjmdes Posted November 21, 2019 Author Share Posted November 21, 2019 46 minutes ago, SNestor said: I made you a video...hope it helps! Awesome! I did not know you could place the profile. Link to comment Share on other sites More sharing options...
SNestor Posted November 21, 2019 Share Posted November 21, 2019 17 minutes ago, DRAWZILLA said: Thanks Steve nice one Thanks! Much appreciated! Link to comment Share on other sites More sharing options...
