RJBPILOT Posted November 15, 2019 Share Posted November 15, 2019 Has anyone built a wood framed accessibility ramp on CA? Would need decking material for surface. Link to comment Share on other sites More sharing options...
Chopsaw Posted November 15, 2019 Share Posted November 15, 2019 You may be able to use a ramp if you can avoid showing it in Vector view. Otherwise build it manually or use a roof plane to generate the framing and an elevated lookout can be multi copied for the decking. Link to comment Share on other sites More sharing options...
RJBPILOT Posted November 15, 2019 Author Share Posted November 15, 2019 no this temporary ramp is made of wood...... I am trying the ramp and will try drawing the framing in. I'll try the roof plane too..... Just need the bottom of ramp to have angled ends on the joists Link to comment Share on other sites More sharing options...
RJBPILOT Posted November 15, 2019 Author Share Posted November 15, 2019 The ramp has limited railing options... can I put a custom railing on it? Link to comment Share on other sites More sharing options...
Chopsaw Posted November 15, 2019 Share Posted November 15, 2019 2 minutes ago, RJBPILOT said: Just need the bottom of ramp to have angled ends on the joists Like plumb cut rafters possibly ? Link to comment Share on other sites More sharing options...
Kbird1 Posted November 15, 2019 Share Posted November 15, 2019 1 minute ago, RJBPILOT said: The ramp has limited railing options... can I put a custom railing on it? Yes turn them off and draw your own with the straight railing tool. M. Link to comment Share on other sites More sharing options...
Chopsaw Posted November 15, 2019 Share Posted November 15, 2019 2 minutes ago, RJBPILOT said: The ramp has limited railing options... can I put a custom railing on it? Yes. Set to "Follow Stairs". Link to comment Share on other sites More sharing options...
RJBPILOT Posted November 15, 2019 Author Share Posted November 15, 2019 I saw the post. You might try a ramp, turn off the default railings, then draw new railings and set them to "follow stairs", then assign a "gap" material to the ramp. Thought straight railing tool would draw a deck over my ramp......Got it. thanks guys Link to comment Share on other sites More sharing options...
Chopsaw Posted November 15, 2019 Share Posted November 15, 2019 1 minute ago, RJBPILOT said: Thought straight railing tool would draw a deck over my ramp That would be cool, but no I don't think so. Mind the "gap" in vector views. Link to comment Share on other sites More sharing options...
Dermot Posted November 15, 2019 Share Posted November 15, 2019 If you turn on the tread surface and make your ramp open underneath, it might be much closer to what you are looking for. You can't automatically add framing to a ramp though. 1 Link to comment Share on other sites More sharing options...
RJBPILOT Posted December 17, 2019 Author Share Posted December 17, 2019 Thanks guys. I used the methods you suggested. 1 Link to comment Share on other sites More sharing options...
