Member Statistics
Similar Content
By robdyck
Shouldn't a schedule create a logical order automatically? For example, if the first column is "FLOOR" shouldn't they be in order from smallest to largest? If column 2 is "ROOM NAME" shouldn't they be alphabetical? I'm sure they used to be this way... what am I missing? The attached image is of a 'fresh' schedule. It seems pretty random to me.
By Evolution
My search of the forum didn’t bring a topic up addressing this particular question. How do I adjust the size of a perspective view before I send it to layout? Is that in editing the active camera settings?
When is end to layout it is so small you can’t see any detail. Grabbing the drag handle and doing a concentric enlarge makes the view blurred. I know it is a simple answer, but I haven’t found it yet?
Thanks
By Evolution
I managed to get one Barrel vault modeled, but attempting the same on the other side of the room (mirror image) is not working. I even tried copy reflect about that didn't work for ME either. It might work for you, if it does please explain what made the difference.
I Checked the structure, on that side and it is the same as the side I was able to model. I even copied the settings of the first (successful vault and pasted them in) unless something changed and I didn't catch it???
The Video I watched showed the same steps I followed and that worked fine on the first one, so why won't it work on the other? The space is the same identical area, only difference is coming into the barrel from the living room side has two (cased openings) the other side coming from the great room has a pair of doors, then into the barrel vault going out into the 2-way cathedral vault (which will be complete when I finally add the second floor above and make that space open below). I was waiting on modeling the second floor since the Owner has made a gzillion floor plan changes just on the first floor. He explained to day (after a dozen emails and texts) that he is "Design OCD"!!!!
Thanks for any direction given.
YARBRO_RESIDENCE_ADDITION.plan
By Michaelx
I have a glass table top that looks like crap with every light in the room reflecting off it like crazy and I can't really see through it. Standard Glass which is the same as the windows and they have no issue. I've turned most of the lights off, no lights close to it, and no outside light. Looks the same in Quick and High Quality. Is there a way to reduce the reflectiveness of a material. I've copied the glass to my User Cat but not really sure what to change.
X8
By Michaelx
Ver X8. Here's what I'm trying to do. A floating soffit (12" below ceiling) with complex shape and rounded corners. I seems you can't make rounded corners on a soffit. No problem. I can do what I need with polyline solid or custom counter top and it comes out just like I want, but I can't place a recessed ceiling light in/under either of those. I've changed the layer to Cabinet, Soffit but still can't place a light.
