Wall Detail and Notes
robdyck
44 minutes ago, Alaskan_Son said:
For now, I would suggest just placing that schedule into a CAD Detail.
I just noticed there is another little trick that might work for you...
Once you get the schedule how you want it, you can copy it, block it and then mirror the block.  It requires a second copy of the schedule or else the numbers won't generate in the block.  Just drag the faulty copy off to the side.
kinda weird that that works. good little trick to know!
