Cursor disappearing
EdKalen
I am having cursor issues that I can't seem to figure out and it's becoming quite the patience tester. As I run the program from the start everything works fine, once I select an elevation view, then go back to the layout view, my cursor disappears from the field but can be seen on the toolbars. I need to restart the program before it appears again.
Running X11 on Windows 10
I am using a Logitech MX laser mouse. Tried to delete it and reinstall it.
Checked for driver updates. No change.
What else can I check?
