Member Statistics
Similar Content
By Kbird1
I don’t use MAC OS myself but many other Users I know do, and I am not sure if this is new in Catalina OS, the latest update ?, but I have had to show People numerous times in the last month or two, how to both turn Scrollbars and the Mouse Right Click Buttons on, some didn't even realize their Mice had a Right Click option. 1. MAC OS seems to have its Scrollbars Turned Off by Default, so they aren’t seen in Chief either after Enabling them in View > Scrollbars
Go to > System Preferences > (search) ScrollBar Behaviors at top left > Open > and Set Scrollbars to Always in the 2nd section.
2. MAC OS also seems to have its Mouse Right Click turned Off by Default too in some cases, so it also can’t be used in Chief ,
for example in the Project Browser in Plan Views > Open Object or create a New Cad Detail by Clicking On the CAD Details Header,
or to Edit Page Information in a Layout.
Go to > System Preferences > Mouse > place a Check in the box for Secondary Button by Clicking on it
( If desired the Secondary button can be your Left or Right Click eg if you are left handed, choose appropriately ).
Sorry I can't add Pics as I don't have a MAC to take some Screen Snips on.
Mick.
By lindatchambers
I have no idea what I changed, but if someone could help me out so I can change it back, that would be super! I am getting this spray icon next to my arrow and I don't know why.
By alheims
A bit frustrated here...
First issue: It doesn't matter what drawing or what size the plan is, I can work away without a problem, but the issue shows up when I open a 3d view and then attempt to close it. I can have multiple 3d views open but if I close them all, my crosshairs disappear from my drawing space. I can move the cursor off the screen to select buttons, but once I place it within the drawing space again, poof, it's gone. If I leave one 3d view open, I can keep working though. So I have to close the plan and reopen, or make sure I leave a 3d view open. This is also apparent within the library 3d views, although that's hit or miss it seems.
Second issue (probably related): I'm working on a window schedule and can zip around in there, UNTIL I attempt to change the label. I click on "Specify Label" but it doesn't change *on screen*. I can type in the box to change it, but can't see what's being typed until after I close the window dbx and open it again.
I'm assuming a graphics card thing, but I don't know for sure. (See attached)
Any suggestions to help alleviate my frustrations would be appreciated. Thanks
By Ferrin
Good afternoon,
Version is x10- For some reason can't figure out why I cant use the mouse orbit tool in Working Plan View. It works just fine in any 3D / Ortho view, just when I get back to the 2DI've got nothing. Everything used to work just fine but I feel like I clicked a button somewhere and now don't know what I clicked.
Very kind
By rcmcdougle
I just upgraded from X 8 and am very happy with X 10 so far. I'm working on a renovation project in an old building in NYC. There are practically no walls that are orthogonal, parallel or perpendicular. I have attached an image that shows my issues.
1) I have a cursor that I have never seen before. What does it mean?
2) It is very tedious to keep toggling the "Ignore off angle walls" indicator. Is there a way to disable this alert in preferences for this plan?
3) I am generating a lot of messy wall intersections. How do I clean these up or turn the display off?
Thanks for the help,
Robb
