builtright3 Posted October 1, 2014 Share Posted October 1, 2014 I'm not sure what the technical term is but I call them "Reference Lines" (refer to attached picture to see what I'm talking about). My question is; Is there a way to put these reference lines on the first floor plan and have them show up automatically on the other floors without having to manually put them on each floor? I put these in on all my drawings manually and I hope I'm not missing something simple. I thought there should be an option or tool to automatically generate reference lines but I haven't found anything yet. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 1, 2014 Share Posted October 1, 2014 Joey, If you create Back Clipped Cross Sections, the camera callouts can be displayed on all floors. But I don't think you can dimension to those. The other option is to create the "Reference" or "Grid" Lines on one Floor and then "Copy" - "Paste - Hold Position" from one floor to the next. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 1, 2014 Share Posted October 1, 2014 Just use a callout, put them on their own layer and in the callout DBX, select "Display on all floors" Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 1, 2014 Share Posted October 1, 2014 On 10/1/2014 at 6:24 PM, DRAWZILLA said: Just use a callout, put them on their own layer and in the callout DBX, select "Display on all floors"Cool tip. I never really thought of the Callout as being usable this way. I can dimension to it - but I can't find where it can be displayed on all floors. Link to comment Share on other sites More sharing options...
builtright3 Posted October 1, 2014 Author Share Posted October 1, 2014 On 10/1/2014 at 6:24 PM, DRAWZILLA said: Just use a callout, put them on their own layer and in the callout DBX, select "Display on all floors" I put them on their own layer set but don't see in the dbx where to display them on all floor? Link to comment Share on other sites More sharing options...
builtright3 Posted October 1, 2014 Author Share Posted October 1, 2014 Ok, what I came up with is to put them on a layer set as Ii usually do but copy and paste to the second floor. But what I didn't know is that I can cut and paste "Hold Position" and it will be same as first floor. That works unless someone has an even better idea? Link to comment Share on other sites More sharing options...
rlackore Posted October 1, 2014 Share Posted October 1, 2014 I think Perry meant that you can set the cross-section camera to display as a callout, then check the box in the dbx to display on all floors. Link to comment Share on other sites More sharing options...
rlackore Posted October 1, 2014 Share Posted October 1, 2014 One technique is to set up a custom layer for your reference lines, then create a custom reference layerset that includes this layer; then when you activate the custom reference layer, you get the reference lines which you can snap to, and use the distance tool with, but they can't be dimensioned. Though, if you have more than two floors, this probably isn't a viable alternative. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 1, 2014 Share Posted October 1, 2014 On 10/1/2014 at 7:28 PM, rlackore said: I think Perry meant that you can set the cross-section camera to display as a callout, then check the box in the dbx to display on all floors. Yes, that's what I said in Post #2. But you can't dimension to a cross section line. There are pro's and con's with either method. CA could/should provide us with the option to display the Callout on all Floors - or maybe just add a "Reference Grid Line" Tool. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 1, 2014 Share Posted October 1, 2014 On 10/1/2014 at 7:28 PM, rlackore said: I think Perry meant that you can set the cross-section camera to display as a callout, then check the box in the dbx to display on all floors. yes Link to comment Share on other sites More sharing options...
builtright3 Posted October 1, 2014 Author Share Posted October 1, 2014 I On 10/1/2014 at 6:24 PM, Joe_Carrick said: Joey, If you create Back Clipped Cross Sections, the camera callouts can be displayed on all floors. But I don't think you can dimension to those. The other option is to create the "Reference" or "Grid" Lines on one Floor and then "Copy" - "Paste - Hold Position" from one floor to the next. I don't need to dimension off them. I just use them to reference the wall for the structural calculations. Its funny I have never use the Paste Hold Position. New it was there but I guess I never thought about how it could help me, Thanks Joe Link to comment Share on other sites More sharing options...
rlackore Posted October 1, 2014 Share Posted October 1, 2014 On 10/1/2014 at 7:34 PM, Joe_Carrick said: or maybe just add a "Reference Grid Line" Tool. Which has been a topic of much discussion in the Suggestions Forum. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 1, 2014 Share Posted October 1, 2014 here it is Link to comment Share on other sites More sharing options...
builtright3 Posted October 1, 2014 Author Share Posted October 1, 2014 Thanks Perry Link to comment Share on other sites More sharing options...
