Angled Wall
I have a story and a half as-built that I'm modeling.  There's an angled wall just above the foyer as shown in the first photo.  How should I go about this?  Polyline solid or is there some tool in Ca that will help?  The second photo is an exterior shot.  Thanks, Kevin.
If you are talking about the wall on the right if you were looking out the front door.  There should not be any issue with chief drawing that.  Just open up your General Plan Defaults and add the angle to Allowed Angles if it is something odd that is not an increment of 15° or 7 1/2°.
Sorry - I should have been more clear.  In the image attached I have marked the sloping wall.  When viewed from the outside it's a sort of dormer.  The second photo shows another vantage point from the inside.  I guess my question is, can CA draw this parametrically (thereby generating framing) or do I need to fill this in with a polyline solid and manually add the framing?  Can CA generate walls that aren't perpendicular to the floor?  The outside ceiling over the porch is flat.
Yes, exactly.  The surface under the red that I show with red arrows.  I think you just answered my question though.  "Chief only does plumb walls".  So, I'll have to fill in with a polyline solid.  Thanks!
1 minute ago, solver said:
Looks like a ceiling plane to me. Drywall on top instead of bottom.
Yes that seems to be it.  Not a wall at all but a manual ceiling plane that comes complete with framing settings.
I'd try a ceiling plane -- no guarantees. Framing may not be perfect especially with the ceiling below, but it might get you started.
And you can do this in Chief, you just give up all the things that make Chief easy.
Just now, solver said:
The new make symbol from selection made this much easier, but I'd still like the see Chief do this naively.
So would @antoine I am sure.  Symbols are great but I would prefer not to build with them.
Very cool!
Eric - I appreciate you looking at this.  I tried drawing the ceiling plan myself this morning and can't get it in the proper location nor can I invert is so that drywall is on the top.  How did you do this?  Kevin
Set up the layers in the ceiling structure tab. Nothing to "invert", just set it correctly from the beginning.
As for placement, take a measurement for the top of the wall it's setting on and match it to the bottom of the ceiling plane.
Joey - thanks for taking the time to answer.  I think I've got it now, however, I end up with a lip where the two planes of drywall need to attach.  I have tried moving the ceiling plane forward to meet on the outside, but CA pushes it back behind the vertical layer of drywall.  Any work around for this or is this as good as it gets?  Thanks again, Kevin
Also, if you have any idea on how to get rid of the baseboard poking through, I'm listening.  I am unable to select the room and delete the baseboard under the moldings panel (it's grayed out).  If I remove it from the wall by ticking "no room moldings", the baseboard doesn't show up in the adjacent room where I need it.  Any ideas?
    29613
    Pav-Arch
    Pav-Arch
