RobUSMC Posted August 7, 2019 Share Posted August 7, 2019 In our office we have folders for each remodeling project, within that folder is another folder for plan files and is where all the final plans and layouts are stored. Once a project is completed that entire project folder is moved to the "Completed Project" folder. Every time I do this, I lose all the images, specs drawings, pdf's, etc. in the layout. I'm sure its because I have changed the file path that was originally used to import those items. What is the best way to to move a folder containing plan and layout files to another folder without losing these imported items / images and not having to manually change / replace these items by changing the file path one by one? See attached. Thanks Link to comment Share on other sites More sharing options...
tommy1 Posted August 7, 2019 Share Posted August 7, 2019 In the project folder, be sure all associated files such as plan files, layout file, images, etc. that are linked to the layout are in that folder. You really don't need a folder within the project folder. Link to comment Share on other sites More sharing options...
RobUSMC Posted August 7, 2019 Author Share Posted August 7, 2019 Tommy we have multiple folders within a project folder to keep all the projects documents separated. How do you associate all files in the folder Link to comment Share on other sites More sharing options...
glennw Posted August 7, 2019 Share Posted August 7, 2019 Rob, For plans, use File>Backup Entire Plan. For layouts, use File>Backup Entire Project. This will save all the externally referenced files that are needed with the plan and layout files, like images, backdrops, textures, pdf's, etc. During this process, Chief gives you the opportunity (not mandatory) to save all the associated files to a zip archive which can be handy for sending to others or for archiving purposes. Link to comment Share on other sites More sharing options...
RobUSMC Posted August 7, 2019 Author Share Posted August 7, 2019 Thanks Glenn. Ill try that Link to comment Share on other sites More sharing options...
tommy1 Posted August 7, 2019 Share Posted August 7, 2019 Rob, you can open the layout you show in your posted layout image and look at the referenced files for that layout. That might give you a clue on how to fix it. Link to comment Share on other sites More sharing options...
glennw Posted August 7, 2019 Share Posted August 7, 2019 Rob, To clarify. When you do a Backup Entire Project from a layout, this will also save the .plan file, the .layout file and all the referenced files, so maybe no need to do the Backup Entire Plan. Link to comment Share on other sites More sharing options...
RobUSMC Posted August 7, 2019 Author Share Posted August 7, 2019 I did back up the entire layout only then moved it to another folder and it kept all the referenced files and images. Thanks Link to comment Share on other sites More sharing options...
lbuttery Posted August 7, 2019 Share Posted August 7, 2019 Rob: for each image in the layout you can open it and click on "save in plan" this could/should be done during the creation of the layout I have been requesting - nay - demanding that CA give us a default option that this save happen auto-matically My partner and I have been bit by this PITA foible since 2005 I just don't understand why CA has failed to fix this issue long - long - ago ;( Lew Link to comment Share on other sites More sharing options...
