Temp Dims - Roadblock
lbuttery
I was using layout to create one image from 3 images
the layout was 24" wide by 8" high - I had the three images on page 1
I had placed some dims to divide the 24" into three panes of 8" each
I decided I needed the layout to be 24" x 12" so I changed the drawing sheet as needed
this changed my 1/4" boundary I had placed on page 0
this keeps the prints away from the paper edge that might get cut off at OfficeMax
I usually click on the boundary and a temp dim appears so I can set it to 1/4"
nope, not happening
I try various things - but no joy - no temp dims at the boundary lines edges
back to page 1 I delete all the lines defining the panes
and now I can get my temp dims on page 0
Is there a way to use temp dims once some dims have been placed ?
if not, I will make a suggestion to remove this roadblock
the attached layout is done in X9
Lew
OAKWOOD_NOTABLES_190724_1215_LBX9.layout
As far as I know Lew it has been that way for many versions ( forever?), and a number of people have asked that Temp. Dims are always active regardless of automatic or manual Dims already having been placed but there has been no feedback as far as I am aware as to why this does not seem to be able to be enabled , it's something I'd prefer myself..
Mick.
Lew, is this what you need ?   I did not delete your dimensions on page 1.
It is definitely a little crotchety and you can't just get it to show up anywhere you click. Also needed to zoom in a little more that would normally be necessary.    I find a lot of things in Chief are zoom dependent and will not work at zoom levels I find comfortable.
Also you might find it easier to use the Sheet Drawing Margins for that purpose.
Chopsaw:
I did zoom in - quite a bit - but maybe not enough ???
anyways I gave up and deleted the dims on page 1 as I didn't need them anymore
I'll check out using the margins settings
I'll make a suggestion that this roadblock be removed as it is a PITA
and is totally unnecessary
Lew
