akabuilder Posted June 19, 2019 Share Posted June 19, 2019 (edited) I have a plan with a gable and hip roof combo. The problem is Gable peak is 10 ft. ceilings and the hip is 9 ft. ceilings. I want them to join at the top. So far I automatically built the roofs, then went back in and manually made adjustments to roof pitch etc. Gable is 5/12 pitch. Hip areas are now 6/12 pitch (so they now are same height). Problem is I have and small overhang where they meet at the ridge - It's something like a T shape. Anyway it overhangs where they join. Any suggestions? Fizette copy.plan Edited June 19, 2019 by akabuilder Visual accuracy Link to comment Share on other sites More sharing options...
Chief16Designer Posted June 19, 2019 Share Posted June 19, 2019 Post the plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 19, 2019 Share Posted June 19, 2019 auto-generated roofs are based upon 3D Geometry where the distance from a gable's load-bearing walls and the angle (pitch) then determine the resulting ridge height. You can get matching perpendicular ridges manually by opening the dialog box of a hip or gable roof to find out the value of its ridge height (top input box) and then copy that value you wish to apply to a perpendicular roof plane. You then open the dialog box of the perpendicular gable roof planes, one at a time and then One: lock the roof plane's "Fascia Top" or "Baseline Height" values by placing a "Radio Button" by that value so its value is not changed by other changes you apply. Two: Once that is done you then copy-paste your copied "Ridge Value" you obtained from the roof dialog box of its ridge value you wish to match and copy-paste that value into its "Ridge input box". Three: when you then click "OK" you then have a perpendicular gable that has a matching ridge with its perpendicular mates. The action of changing the ridge value secondarily changes the roof plane's pitch or angle. DJP 1 Link to comment Share on other sites More sharing options...
SNestor Posted June 19, 2019 Share Posted June 19, 2019 16 hours ago, akabuilder said: I have a plan with a gable and hip roof combo. The problem is Gable peak is 10 ft. ceilings and the hip is 9 ft. ceilings. I want them to join at the top. So far I automatically built the roofs, then went back in and manually made adjustments to roof pitch etc. Gable is 5/12 pitch. Hip areas are now 6/12 pitch (so they now are same height). Problem is I have and small overhang where they meet at the ridge - It's something like a T shape. Anyway it overhangs where they join. Any suggestions? Fizette copy.plan I think everyone comes across this issue now and then...thought it was a good reason to make a video. Hope it helps! 1 Link to comment Share on other sites More sharing options...
akabuilder Posted June 21, 2019 Author Share Posted June 21, 2019 Sorry for the delayed response here...This is great! A video is exactly what I needed - Thankyou Much SNestor! I'll be checking out your other YouTube videos Link to comment Share on other sites More sharing options...
