auto dims overlapped
ChiefUserBigRob
In "Edit - Default Settings - Dimensions" dialog you can: Change the font size of the numbers and dimension point arrows and on the "Primary" Tab change the fraction round-off factor which will also reduce the amount of space, dimension strings occupy.
I doubt if the 2 different types of dimension strings are "all one entity".
They are most likely 2 separate dimension strings.
Select one of them and drag it out of the way by using the main grip.
Just out of curiosity, do you need to dimension to the center of the tub and a dimension to the toilet? Accurately dimensioned walls define where the tub and toilet should go, unless you have some special reason to vary from standard. Eliminating those types of dimensions will clean up the dimension string. Also, dimensioning to the center of doors and windows will help unless you need the sides dimensioned. Just a suggestion.
    30405
    ElzaBDesign
    ElzaBDesign
