SNestor Posted May 25, 2019 Share Posted May 25, 2019 Is there a way to accomplish a roof section as shown in the using the roof and ceiling tools in Chief X11? What I would like it to have the screen in the roof align near the top chord of the rafter. I know I can use P-Solids...just wondering if there was a more "automatic" method that I'm missing. Thanks! Link to comment Share on other sites More sharing options...
Chopsaw Posted May 25, 2019 Share Posted May 25, 2019 If you use a second roof plane for just the screening it should work ok. Just copy the original one and drop it 2" and gut the rest of the options. A bit of mucking around and I don't think it can be done fully auto but maybe good enough for the situation. Link to comment Share on other sites More sharing options...
SNestor Posted May 25, 2019 Author Share Posted May 25, 2019 1 hour ago, Chopsaw said: If you use a second roof plane for just the screening it should work ok. Just copy the original one and drop it 2" and gut the rest of the options. A bit of mucking around and I don't think it can be done fully auto but maybe good enough for the situation. Good idea. I will give it a try. Thanks! Link to comment Share on other sites More sharing options...
Kbird1 Posted May 25, 2019 Share Posted May 25, 2019 1 hour ago, SNestor said: Is there a way to accomplish a roof section as shown in the using the roof and ceiling tools in Chief X11? What I would like it to have the screen in the roof align near the top chord of the rafter. I know I can use P-Solids...just wondering if there was a more "automatic" method that I'm missing. Thanks! You know better than to not post a Plan ... Chopsaw would of fixed it for you already..... or Eric..... Can't you just use the Roof Surface for the Mesh if you want it aligned with the top of the Rafter ? if you meant the bottom you could use just use the ceiling surface no? ( your image doesn't show the screen at the top of the Rafter though) I am thinking this is a Greenhouse type structure but with mesh not glass? maybe not? M. Link to comment Share on other sites More sharing options...
SNestor Posted May 25, 2019 Author Share Posted May 25, 2019 I’ve already got a roof with screen as the ceiling surface...I was just wondering if it was possible to get the screen in the center of the rafter. I think the solution is to copy the roof I have “in place”...then use transform/replicate and move it up or down as needed. And some other editing too. And yes...I should have posted a plan. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 25, 2019 Share Posted May 25, 2019 just ribbing ya a bit.... Ahhh so the Detail was correct then , I'd think a Ceiling Plane would be pretty easy too with the framing turned off.... M. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 25, 2019 Share Posted May 25, 2019 42 minutes ago, Kbird1 said: Ceiling Plane would be pretty easy too with the framing turned off.... Yes that would be a less complex solution. And seems it would work fine. Link to comment Share on other sites More sharing options...
SNestor Posted May 25, 2019 Author Share Posted May 25, 2019 1 hour ago, solver said: Ceiling plane. Thanks Eric. That is exactly how I have it now. I was just trying to see if there was a way to get the screen in the rafter center (or close) thanks all for the tips and suggestions. Link to comment Share on other sites More sharing options...
