Foundation Plan Pony Wall
Hap-45
User - Hap
Premier X11 Build 21.2.0.48x64 May 1 2019
I have some foundation walls that are pony walls, lower portion is concrete with footing, upper wall is wood frame. I am drawing the foundation plan for the concrete contractor so turned off display of the layer named Walls, Pony, Upper. When I do that, the upper wall does not display but neither does the lower concrete wall. The lower concrete wall is set to be on layer named Foundation which is set to display. What I am experiencing has me baffled.
Thanks for any help!
If you have a Pony wall both upper and lower sections displayed on the same layer. Hit a Layer tab to verify, see picture below.
The discussion above relates to "Display in Plan View" option. See the bottom section.
