Appliances won't show up in Elevations
LBILTD
Check your layer settings to make sure you have fixtures, interior turned on in the layer you are in. Do you mind filling out your signature, with the software version you're using and a little info on your hardware / computer specs will help. Go to your profile and select it>then in the drop down do down to settings, then in the drop down that opens on the lower left hand of your screen, select Signature, and fill in as much info as you can.
Thanks
