LBILTD Posted April 3, 2019 Share Posted April 3, 2019 Hello! I opened up an elevation on a wall of appliances and none of the appliances would show up in elevation. They would only be visible in 3D and plan view. Any ideas? Thanks in advance! Link to comment Share on other sites More sharing options...
Kbird1 Posted April 3, 2019 Share Posted April 3, 2019 Sounds like in Elevation you have the Layer the Appliances are on not Displayed...... I think they are usually on Fixtures,Interior M. Link to comment Share on other sites More sharing options...
Evolution Posted April 3, 2019 Share Posted April 3, 2019 Check your layer settings to make sure you have fixtures, interior turned on in the layer you are in. Do you mind filling out your signature, with the software version you're using and a little info on your hardware / computer specs will help. Go to your profile and select it>then in the drop down do down to settings, then in the drop down that opens on the lower left hand of your screen, select Signature, and fill in as much info as you can. Thanks Link to comment Share on other sites More sharing options...
solver Posted April 3, 2019 Share Posted April 3, 2019 When something that you expect to see is missing from a view, start by switching to the All On layer set -- and make sure all layers are on. If the missing items show up, you know it's a layer display problem. Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 3, 2019 Share Posted April 3, 2019 The only other thing it could be is that the elevation camera's "Back Clip" setting, excludes the appliances. It is probably just a "Display Options" dialog omission as has been suggested above. DJP Link to comment Share on other sites More sharing options...
LBILTD Posted April 10, 2019 Author Share Posted April 10, 2019 Hi All! It was a display setting on the Back Clip however my file ended up getting corrupted and I lost everything. Thank you for all the help! Link to comment Share on other sites More sharing options...
