OnlineBuilder2 Posted March 25, 2019 Share Posted March 25, 2019 Does anyone know why you can't select multiple rooms and change the Room Type for them? It would be good to select all the carpeted bedrooms and change the room type and fill type at once. Link to comment Share on other sites More sharing options...
OnlineBuilder2 Posted March 25, 2019 Author Share Posted March 25, 2019 Thanks. I never used Object Eyedropper. It would have saved me hours. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 25, 2019 Share Posted March 25, 2019 You can also set up the default ,rooms DBX ,so it goes faster for you. There you can change multiple rooms Link to comment Share on other sites More sharing options...
DRyeHD Posted May 9, 2019 Share Posted May 9, 2019 So I understand, if I have a master bath with a toilet separated by a door, there is no way to make the two "rooms" act like one master bath? As shown in the attachment, the shower area also does not get included. I can break a CAD polyline and drag it so it covers the toilet area. But I have not found a way to save this a one area. Just to re-check, can this be done? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 9, 2019 Share Posted May 9, 2019 Make the Wall to the toilet "No Room Definition". Link to comment Share on other sites More sharing options...
DRyeHD Posted May 9, 2019 Share Posted May 9, 2019 Will do next time. Thanks. Link to comment Share on other sites More sharing options...
Michael_Gia Posted May 9, 2019 Share Posted May 9, 2019 59 minutes ago, Joe_Carrick said: Make the Wall to the toilet "No Room Definition". But if you change the wall to no room def then you won’t be able to independently change stuff in those separate rooms right?. If it’s for room name and area and you want to group them as one area then use a room area polyline that includes the shower and toilet and give that a name and area etc. Instead of the room label. (I learned that from you, by the way) Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 9, 2019 Share Posted May 9, 2019 59 minutes ago, Michael_Gia said: (I learned that from you, by the way) I don't think so. That's not what I do. If I need different floor finishes I use a Floor Material Region. Similar for walls Link to comment Share on other sites More sharing options...
