MarkSM Posted March 12, 2019 Share Posted March 12, 2019 I'm trying to place an auto dormer. I'm getting the whole "walls are in the way" message. The problem is that it won't let me delete the walls that are in the way. Why? any help would be greatly appreciated. connally.plan Link to comment Share on other sites More sharing options...
MarkSM Posted March 12, 2019 Author Share Posted March 12, 2019 5 minutes ago, solver said: Picture and plan don't match. It should be the same scenario either way. Just a different size dormer. Thanks Eric Link to comment Share on other sites More sharing options...
tommy1 Posted March 12, 2019 Share Posted March 12, 2019 Auto dormers (not floating)) will require walls at the back of the dormer. Don't know what you're trying to do. If all else fails, try placing a blank floor above (don't move roof) and then place a floating dormer on new floor. (display roof on floor above) Didn't look at your plan. Link to comment Share on other sites More sharing options...
tommy1 Posted March 12, 2019 Share Posted March 12, 2019 You might just be able to display roof at attic level and use a floating dormer. I'll look at your plan later unless someone else does. Link to comment Share on other sites More sharing options...
MarkSM Posted March 12, 2019 Author Share Posted March 12, 2019 8 minutes ago, tommy1 said: Auto dormers (not floating)) will require walls at the back of the dormer. Don't know what you're trying to do. If all else fails, try placing a blank floor above (don't move roof) and then place a floating dormer on new floor. (display roof on floor above) Didn't look at your plan. Sorry Tommy. I should have been more c lear. I just want a floating dormer. Link to comment Share on other sites More sharing options...
tommy1 Posted March 12, 2019 Share Posted March 12, 2019 Just now, MarkSM said: Sorry Tommy. I should have been more c lear. I just want a floating dormer. Try as I mentioned. Link to comment Share on other sites More sharing options...
MarkSM Posted March 12, 2019 Author Share Posted March 12, 2019 4 minutes ago, tommy1 said: Try as I mentioned. I went to the attic floor and even tried adding a second floor. No luck. Its the two walls underrate my dormer that it doesn't like. I just can't figure out why it won't let me delete those walls. Link to comment Share on other sites More sharing options...
MarkMc Posted March 12, 2019 Share Posted March 12, 2019 Selected roof planes, show on floor above-floating dormer was no issue. For auto dormer add wall on attic floor, change the wall to attic, place dormer. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 12, 2019 Share Posted March 12, 2019 I feel like there are too many extra ideas being thrown out here. You shouldn't need to add floors or move roof planes or anything out of the ordinary. Just place the dormer on the attic level. Should be as simple as that. Link to comment Share on other sites More sharing options...
tommy1 Posted March 12, 2019 Share Posted March 12, 2019 I've always displayed my roofs above and usually reference walls below so I know for sure where I'm placing it. Then display roof below.Too many steps? Oh well. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 12, 2019 Share Posted March 12, 2019 8 minutes ago, tommy1 said: I've always displayed my roofs above and usually reference walls below so I know for sure where I'm placing it. Then display roof below.Too many steps? Oh well. I'm not saying its not a valid method, I'm just suggesting that the extra steps might just be adding confusion. The problem here is that the floating dormer can't be placed where there are conflicting walls. The answer is to place the dormer on a floor where there are no walls in the way. Adding a floor is not necessary to solve the problem (and in this case only added confusion since the extra floor causes some auto generated attic walls), and moving roof planes is not necessary to solve the problem (could be addressed anyway by simply turning on the reference display too). I'm just trying to narrow the focus in on the actual problem without introducing unnecessary extra steps. Link to comment Share on other sites More sharing options...
builtright3 Posted March 13, 2019 Share Posted March 13, 2019 I placed a floating dormer in the location you are calling out and I didn't have a problem with it. Or is that not what you want Link to comment Share on other sites More sharing options...
