DeveloSpec Posted February 18, 2019 Share Posted February 18, 2019 Does anyone know how to cut a curb? I placed a polyline sidewalk and connected it to a road and the the curb apron does not build. (LEFT SIDE OF PHOTO) I placed a regular sidewalk and connected it to a road and the curb apron cuts pefect. (RIGHT SIDE OF PHOTO) any help would be great. Is there a manual way to cut a curb? Link to comment Share on other sites More sharing options...
DeveloSpec Posted February 18, 2019 Author Share Posted February 18, 2019 no because the sidewalk on the left is different angles.. not straight (can't see in the photo) and as far as I know, a regular sidewalk can not be in different shapes. there has to be some way to cut a curb in CA! Link to comment Share on other sites More sharing options...
dshall Posted February 18, 2019 Share Posted February 18, 2019 On 2/18/2019 at 3:43 PM, DeveloSpec said: ...... there has to be some way to cut a curb in CA! Expand I think only a driveway cuts a curb. I can't believe you cuts the curb with a sidewalk. 1 Link to comment Share on other sites More sharing options...
glennw Posted February 19, 2019 Share Posted February 19, 2019 On 2/18/2019 at 4:37 PM, dshall said: I can't believe you cuts the curb with a sidewalk. Expand Scott, Just about every sidewalk here cuts the kerb. I am guessing it is mandatory - access for the disabled, mums with prams, etc. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 19, 2019 Share Posted February 19, 2019 On 2/18/2019 at 2:22 PM, DeveloSpec said: Does anyone know how to cut a curb? I placed a polyline sidewalk and connected it to a road and the the curb apron does not build. (LEFT SIDE OF PHOTO) I placed a regular sidewalk and connected it to a road and the curb apron cuts pefect. (RIGHT SIDE OF PHOTO) any help would be great. Is there a manual way to cut a curb? Expand Normally a Road is not used for a Driveway as you have done , so you wouldn't need the Curb Apron at the Sidewalk , just at the actual Road. M. Link to comment Share on other sites More sharing options...
parkwest Posted February 19, 2019 Share Posted February 19, 2019 On 2/18/2019 at 3:43 PM, DeveloSpec said: no because the sidewalk on the left is different angles.. not straight (can't see in the photo) and as far as I know, a regular sidewalk can not be in different shapes. there has to be some way to cut a curb in CA! Expand Try a short length of straight sidewalk on the left, as Eric suggested earlier, and then run your curved sidewalk up to the end of the straight. Link to comment Share on other sites More sharing options...
parkwest Posted February 19, 2019 Share Posted February 19, 2019 On 2/19/2019 at 5:15 AM, Kbird1 said: Normally a Road is not used for a Driveway as you have done , so you wouldn't need the Curb Apron at the Sidewalk , just at the actual Road. M. Expand I make all my driveways using the road function, sidewalks also. Makes it very easy to add a stamped concrete pattern to the edge by editing the curb. Link to comment Share on other sites More sharing options...
dshall Posted February 19, 2019 Share Posted February 19, 2019 Glenn, I guess I never realized a sidewalk could cut curbs. So what is the difference between a terrain path and a driveway? Is the only difference the layer they reside on? Link to comment Share on other sites More sharing options...
glennw Posted February 20, 2019 Share Posted February 20, 2019 On 2/19/2019 at 7:00 PM, dshall said: Glenn, I guess I never realized a sidewalk could cut curbs. So what is the difference between a terrain path and a driveway? Is the only difference the layer they reside on? Expand I think so. Link to comment Share on other sites More sharing options...
glennw Posted February 20, 2019 Share Posted February 20, 2019 On 2/18/2019 at 3:43 PM, DeveloSpec said: no because the sidewalk on the left is different angles.. not straight (can't see in the photo) and as far as I know, a regular sidewalk can not be in different shapes. Expand Can you post a plan diagram of the left hand sidewalk/road junction. Is it curved or bent? If a sidewalk runs into a road at an angle, the sidewalk will trim to the road. You can snap sidewalks end to end and form a "bent" sidewalk. Link to comment Share on other sites More sharing options...
