Polyline Sidewalk Apron Curb Cut Not Working
DeveloSpec
Does anyone know how to cut a curb?
I placed a polyline sidewalk and connected it to a road and the the curb apron does not build.  (LEFT SIDE OF PHOTO)
I placed a regular sidewalk and connected it to a road and the curb apron cuts pefect. (RIGHT SIDE OF PHOTO)
any help would be great.
Is there a manual way to cut a curb?
Normally a Road is not used for a Driveway as you have done , so you wouldn't need the Curb Apron at the Sidewalk , just at the actual Road.
23 hours ago, DeveloSpec said:
no because the sidewalk on the left is different angles.. not straight (can't see in the photo) and as far as I know, a regular sidewalk can not be in different shapes.
there has to be some way to cut a curb in CA!
Try a short length of straight sidewalk on the left, as Eric suggested earlier, and then run your curved sidewalk up to the end of the straight.
I make all my driveways using the road function, sidewalks also.  Makes it very easy to add a stamped concrete pattern to the edge by editing the curb.
Can you post a plan diagram of the left hand sidewalk/road junction.
Is it curved or bent?
If a sidewalk runs into a road at an angle, the sidewalk will trim to the road.
You can snap sidewalks end to end and form a "bent" sidewalk.
