jpdesign Posted February 12, 2019 Share Posted February 12, 2019 Hello, What may cause the problem as show in the attach image? Its' a roof over an area claimed as porch. Thanks, Josh Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 12, 2019 Share Posted February 12, 2019 That's the space between the top of your roof plane and the ceiling defined for your roof plane. If you were to frame that roof and turn the rafter framing layer on then you would see rafters in there. Link to comment Share on other sites More sharing options...
jpdesign Posted February 12, 2019 Author Share Posted February 12, 2019 46 minutes ago, Alaskan_Son said: That's the space between the top of your roof plane and the ceiling defined for your roof plane. If you were to frame that roof and turn the rafter framing layer on then you would see rafters in there. Thanks for your reply. How can I fix it? Link to comment Share on other sites More sharing options...
joey_martin Posted February 12, 2019 Share Posted February 12, 2019 Make sure you have the box checked for a ceiling over that "room". Looks like no ceiling is present, unless you didn't want on, then you need to check the size of the framing members based on the size of the fascia you have spec'ed. Link to comment Share on other sites More sharing options...
jpdesign Posted February 12, 2019 Author Share Posted February 12, 2019 24 minutes ago, solver said: What do you want to see there? Expect to see no space. Later on when roof framing is on, want to see the rafter. Like the eave in the image. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 12, 2019 Share Posted February 12, 2019 2 hours ago, jpdesign said: Expect to see no space. Later on when roof framing is on, want to see the rafter. Like the eave in the image. Sounds to me like you need to change your rafter size in the roof structure dialog. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 12, 2019 Share Posted February 12, 2019 3 hours ago, jpdesign said: Expect to see no space. Later on when roof framing is on, want to see the rafter. Like the eave in the image. Post the Plan file ( while it not open in Chief ) so people don't have to guess what the real situation is.... Be a good Idea to fill in your Forum Signature too , so we know what Software you are using.... M. Link to comment Share on other sites More sharing options...
NRST8TRKR Posted February 12, 2019 Share Posted February 12, 2019 Looks like the roof is set up for 2"x10 rafters Link to comment Share on other sites More sharing options...
