hide units - meteric
RobWhite
I am aware of generally hiding the metric units on dimension lines and default door & window labels, but I am not sure how hide the units when I specify the height and width of a window under the specify label section of the window or door menu box. Can anyone tell me how to those metric units. See attached
ScreenShot110119.pdf
As far as I know Chief's built in Object Macros like %width% or %height%  include the Unit by default
But using %FormattedOpeningWidth% x %FormattedOpeningHeight% in your Own Marco may work for you.... personally I don't use this one as I don't like the fact in Imperial it uses Feet not Inches  ie a 32"x48" window is seen as  28x40 , which is a sure way to get it framed incorrectly I have found so I use the one Chopsaw Suggested.....except 16ths.
Rob's PDF for Others
