Need help determining how to set roof elevation.
GSD123
23 minutes ago, GSD123 said:
I think I checked ceiling height, wall height and they are correct.
They are all zero.
Go to Edit > Reset to Defaults, All Floors, Floor and Ceiling heights. Rebuild roof.
You have other problems, though, with your Current Floor defaults. Get that corrected too.
14 minutes ago, Chrisb222 said:
They are all zero.
Thank you for the help.
What do you see in the floor defaults that is wrong?
It just looked odd, but maybe not. The perspective view showed a large gap beneath the roof but it turns out your exterior walls were defined as Foundation walls, and you need to reset them to Default Wall Heights in the wall DBX Structure tab.
Robert's (racklore) Pic's show you what's wrong everything is set to 0" eg Room ceiling hgt which explains the Roof on the Slab.
Click Defaults Boxes ( assumes Floor Defaults as set as desired 1st) to put it back to 120" and turn Auto Roof Build back on to help fix the Roof.
Then use Edit>Reset to defaults per this pic as suggested....
image.thumb.png.6417f3e3a5f790c9555e64e2d12582ad.png    which does this image.thumb.png.43ef8ae4ffcbf9b1220b698458e6595c.png
