Vertical footing ?
Chrisb222
10 hours ago, glennw said:
Chris,
Wall Specification dbx>Foundation panel>Footing>Vertical Footing?
No, already checked that, as far as I can tell all the wall specs are the same when the file is opened in X9 and X10.
8 hours ago, javatom said:
Look at it in elevation and click on the footings (not the wall).  Once you have it highlighted, grab the handle of the vert. footing and drag it over to the end of the other one and it will disappear.
So, it's affirmed that X10 changed the default structure of a footer to automatically generate this vertical footer? How odd.
When I scoot the footer over to make it disappear, the view from 90° still shows a line at the corner of foundation wall:
In X9, by default there is no vertical footer or line at the wall corner:
20 minutes ago, Alaskan_Son said:
Try placing a break in the foundation walls at those 2 locations.
That worked... sorta.
It got rid of the vertical footer but added the lines in the wall corners, and messed up the wall above:
Just not sure why these odd vertical footers are being generated. The X9 behavior was correct...
I agree, the behavior seems incorrect.  Make sure it gets reported to tech support.
