cburkit Posted January 14, 2019 Share Posted January 14, 2019 Just adding basic dormers. Left with open triangles. I already tried to have the polygon create a shaft through but that only made it worse. What’s the best way to get a smooth transition from the roof pitch into the former walls? Link to comment Share on other sites More sharing options...
cburkit Posted January 14, 2019 Author Share Posted January 14, 2019 I tried that already. That lands the wall on the floor and cuts it off at the roof. I want the wall to fill only the triangle so that it’s flush to the vaulted ceiling finish. I’ve also tried to adjust the dormer itself Link to comment Share on other sites More sharing options...
cburkit Posted January 14, 2019 Author Share Posted January 14, 2019 I apologize in advance. I come from auto and archi cad and am still learning the ins and outs of this software. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 14, 2019 Share Posted January 14, 2019 If you are having issues , it is always best to post the.plan file if you can ( make sure not open in Chief 1st) , also it is best to use the Snipping Tool in Accessories or some other Screen Capture program so the Pics are clearer.....Phone pics never seem to look good ...but I think the camera lens may need a clean too in this case. This is not uncommon with steep pitched Roofs in particular ....... sometime the Wall Polyline will do it other times not.... Link to comment Share on other sites More sharing options...
cburkit Posted January 15, 2019 Author Share Posted January 15, 2019 newHOUSE4.plan Link to comment Share on other sites More sharing options...
cburkit Posted January 15, 2019 Author Share Posted January 15, 2019 1 hour ago, solver said: Be careful when drawing roof planes, and walls to get them square. This roof is out just a bit. And here is your plan. newHOUSE4 (eric).zip That’s because I had to do it by hand. For some reason “join roof” is not working like it should unless I’m missing something. I even tried building 4 walls and get the same error message that they cannot be joined. I’ve been using this particular software less than a month, so I’ve still got some bugs to work out. Thanks for your help. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 15, 2019 Share Posted January 15, 2019 7 minutes ago, cburkit said: For some reason “join roof” is not working like it should unless I’m missing something. The thing new users typical miss is that you have to select the edge that you want to join to another edge. Next click Join Roof Planes, and lastly, pick the edge that you want to join to. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 15, 2019 Share Posted January 15, 2019 On a simple Roof like this one it really shouldn't be needed at all, this is easy for and Auto Roof Build , and you could also use Auto Floating Dormers too..... M. Link to comment Share on other sites More sharing options...
cburkit Posted January 15, 2019 Author Share Posted January 15, 2019 1 hour ago, Kbird1 said: On a simple Roof like this one it really shouldn't be needed at all, this is easy for and Auto Roof Build , and you could also use Auto Floating Dormers too..... M. sorry. I am old school. This is how I designed the house. Cad is only for clients and subs. I do everything by hand first. When using software, I still prefer to learn the hard method first. Using automated methods makes it too easy to miss details... in my opinion Link to comment Share on other sites More sharing options...
Kbird1 Posted January 15, 2019 Share Posted January 15, 2019 2 hours ago, cburkit said: sorry. I am old school. This is how I designed the house. Cad is only for clients and subs. I do everything by hand first. When using software, I still prefer to learn the hard method first. Using automated methods makes it too easy to miss details... in my opinion Nothing wrong with Learning Manual Roof Planes or even Manual Dormers , all good to know as it will be required at some point , but with a straight Gable Roof Auto is a Time saver, I still let Auto do it's thing 1st and then make changes as/if needed. Auto Dormers aren't good in all situations but they usually work fair well at eliminating the Issues you saw. M. Link to comment Share on other sites More sharing options...
SNestor Posted January 18, 2019 Share Posted January 18, 2019 On 1/14/2019 at 2:35 PM, cburkit said: Just adding basic dormers. Left with open triangles. I already tried to have the polygon create a shaft through but that only made it worse. What’s the best way to get a smooth transition from the roof pitch into the former walls? Take a look at my video on How to build Manual Dormers. Hope it helps... 2 Link to comment Share on other sites More sharing options...
Evolution Posted January 18, 2019 Share Posted January 18, 2019 Great Video Steve! 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted January 18, 2019 Share Posted January 18, 2019 17 hours ago, SNestor said: Take a look at my video on How to build Manual Dormers. Hope it helps. Thanks Steve..... 1 Link to comment Share on other sites More sharing options...
